Which looks better
Hi All:
I personally really like the look of the stock 40/45 Series dash cluster, but I'll admitt that the custom gauge cluster you've made-up looks good also.
I think you should use your custom gauge cluster. Why? first off, you have put all this time and effort into it, might as well use it. Also, I've heard way too many times that the stock gauges aren't really that accurate.
Good luck with your project!
Regards,
Alan
Seattle
rockcod said:
I am doing the same thing with Auto Meter Phantom gauges. Are you going to have enough room for the steering column?
Looks good, like to see what it looks like in the dash.
I was wondering the same thing. Does the bottom of your cluster clear the column?
Yes, I checked the alignment of the guage plate and the stock column. The plate clears, but the dash is made with a brace that is shaped like an upside down "V" right above the column. That brace has to be cut out to allow the guages to fit. Well, it is really not a brace, but just more of the dash metal.
BTW, if anyone has an old FJ40 wiring harness, I would like the male connector that goes from the stock harness to the stock guages. I can use that connector and the wires from it to hook up to the new guages. That way, I have a means of disconnecting the new guages all at once. Hmm, I wonder if that connector can still be purchased?
Rice! Cool setup!! Where are you turn signal and high beam lights? You got all those guages int there! How much did you cut of the stock dash?
I knew I forgot something! Fact is I just have not drilled for the signals and high beams yet and vehicle inspector doesn't seem to care. I did a little shaving on the tabs for the 2 screws and the bottom brace but otherwise no cutting.
For those that want to know, or those who don't care! A knew speedo cable from the place in Wi that Autometer recommends will built a new 7' speedo cable that will fit LC on one end and the Autometer on the other for $50. The cables come with either a plastic cover or metal cover. Metal is $15 more.
How long is a stock LC fj40 speedo cable? Trivia question for someone.
More specific in the year of the vehicle please, Toyota made a few different ones from 1969 to 1984, for the 40 series.... ;)
Here you go.
http://www.speedometersolutions.com/
The guy I talked to really didn't seem concerned by my asking for 1973 LC speedometer on one end and the autometer on the other. So, I am sure it doesn't matter what year, just as long as the end can be identified.
I wonder if they lengthen parking brake cables?
I like the autometer setup. OEM is great but your left without a tach.
When I got my new speedo cable I think it was from who you mentioned. I got the 7 footer and it was just right so I could route it up and out of the way from the exhaust which claimed the last cable.
When I did the sending unit on the gas tank I tried using the flange it came with put couldn't get it to seal very well. When the tank was full it would slosh out at the sending unit :doh: Took it off and mounted it to the factory flange. Quick and simple. :cool:
