Old pic or is the head back on already?I ended up with these, work pretty well on an early 2F block with a big cap dizzy. Might fit better with a small cap...
Old pic, head still in the shopOld pic or is the head back on already?
I am using them for a 1975 and a 1984 using a Holley sniper on the 75 and stock carb on the 84….from the photos @Pighead shows, the only difference I see is the spark plug boots are at a 45 degree angle on mineWhat year 40 did you order these for. When I put in my year('77) it comes up with a different part number. Just don't wanna order the wrong thing.
Thanks
Good chance your center arm also needs some attention if 1.5" is the play after adjustment.Oil change with 20w40 (and ZDDP), then adjusted the steering box to take out some play (seems like the final adjustment that was needed to tighten her up). Play is now ~1.5 or so - big difference. Then contemplated just how much has changed on these rigs in 40 years
I can absolutely agree that the center arm will make a bigger difference. The problem I have is breaking assembly apart on the hub. Took more strength than I had so it took a very secure vice, a 1/4 can of penetrating oil and an extension on my breaker bar to rebuild itGood chance your center arm also needs some attention if 1.5" is the play after adjustment.
Rebuilt the center arm recently. Might try tightening it a bit. Candidly, could tighten the steering box a bit more, just worried about doing too much and increasing wear.Good chance your center arm also needs some attention if 1.5" is the play after adjustment.
Installed my winch that my girlfriend got me for my birthday.
oh yeah she does. She kept asking what to get for this build. (she buys a part for all of my builds so she can point to her friends and gloat)Your girlfriend knows how to pick a birthday present!
Gotta be careful telling your girlfriend you want a winch for your Birthday!Installed my winch that my girlfriend got me for my birthday, it was frustrating because the previous owner installed the power steering box a bit higher than he should’ve. But I think it turned out really nice.
I like those tires. What are they and what size?Installed my winch that my girlfriend got me for my birthday, it was frustrating because the previous owner installed the power steering box a bit higher than he should’ve. But I think it turned out really nice.
They are 19 yo 33x12.5x15 on headlocks I have had this truck in storage for 14 years. But still holding air.I like those tires. What are they and what size?
Finished this one up, all the way down to new brass butterfly screws and every steel part zinc plated. Well that’s a lie, the slow cut valve rod isn’t - which I need to find a way to remove without breaking the aluminum.
mine looked in similar condition........ I filled scratches and holes w epoxy, sanded smooth, then did the cygnus white version of monstaliner on top. Not sleek and glossy, but w a rack under it I feel it works.Im going to consider just ordering one from Classic Cruisers and remove the rain gutter on the one I have currently considering it’s in really good shape from what I can tell.
