In that pic there are fuel supply and return bulkheads as well as a 4 gauge and 0/1 gauge electrical bulkheads.So the bulkhead connector is for the fuel feed/return lines from gas tank?
They are welding magnets made by MagSwitchWhat is the yellow magnet tool? Care to share? Cool build.
Added 0/1 gauge wire for my amps. 180 amp breaker by the battery and then a maven bulkhead connector to pass through the floor.
P
Not good to run the belt at that angle... will wear out prematurelyI had envied those new 2F alternator tensioners I've seen lately. Was hesitant to buy one as i do not have a Toyota alternator. It's a Herr. When i swapped in the 2F block, i did not have the upper bracket or tensioner. So i made my old late F alt bracket fit.
Just pounded it between two rocks until it sorta fit. Then used a crowbar to adjust the tension.
Then i heard, after i asked, that i could get a good used one locally. So i did. (Thanks @pardion)
Simplicity itself to install, had to fiddle with bolts & washers & stuff. Probably should grind down the mount a little to make it perfect.
No, certainly not ideal. A compromise i made to keep the power steering from throwing beltsNot good to run the belt at that angle... will wear out prematurely
Perhaps Toyota-san did not envision Saginaw pumps on his early 2F block, i dunno.I’m puzzled how belt alignment like that helps keep the power steering from throwing belts. Why can’t they all be aligned at the same time.
I tried various iterations, with spacer, without, different belts & different pulleys, shimming funny.
I am not a guru. We all know that.
One run i tossed and or shredded 3 power steering belts.
This is the best i can do without professional help or starting a thread about it
Grab some spacers to space the Alt back and then make a bracket to anchor at the head where the ground is. You’ll need to have the ear extended for the tensioner.No, certainly not ideal. A compromise i made to keep the power steering from throwing belts
Fast forward to the year 2022 and they are still sitting there.Driving thru Crescent City,California yesterday and saw these
JP View attachment 1753192View attachment 1753193View attachment 1753194View attachment 1753195View attachment 1753196
Just so happens I will be checking to see next week.Fast forward to the year 2022 and they are still sitting there.
I drove by about an hour ago!Just so happens I will be checking to see next week.
Many of them have better bodies than mine… such a shame to see them just Rusting In Pieces.I drove by about an hour ago!
