How do you plan on mounting it? Does it stick down much further than the frame?Started building a rear fuel tank.
It’s an identical clone of the ManaFre rear tank. It drops down below the frame for sure, but it shouldn’t hit anything unless you drop off of a perfectly vertical ledge that’s more than 2.5 feet tall.How do you plan on mounting it? Does it stick down much further than the frame?
My tank like that is mounted by a pair of holes going through the middle of it. I've read that in time the welds around the pipes, going through, can crack in time. It's somewhat shallower than what yours appears to be.
You’ve probably figured it out but…….. the latches can be adjusted - so you don’t have to slam your door!So. My girlfriend had a headache, a box was delivered by UPS and sitting at my gate, and we had a 35% chance of rain. Those things added up to... an excuse to take off work!!Naturally, after feeding a Tylenol to my girlfriend, I went straight to work on the FJ40. I quickly got the doors on, but here is the rest of the story. I bought the @SMG door pins a while back, and it was time to use them. I followed the directions in his post about cleaning the hinges with a drill bit etc. I assembled the passenger side first with some high quality spay lube, Zep 45, but it was more difficult than I expected, a little more hammer required than I would have thought. Then for the driver side I used a Q-tip to apply assembly lube to all surfaces. That was the trick! After assembly the passenger side was immediately rock solid, but the driver side still had a rattle. Then I discovered that the driver side wasn't actually closing all the way... The latch seems to have 2 stages of closing and it was only getting half way. Then, I slammed the door and voila! The latch closed all the way and it was super tight! So now I guess I have to sleep some tonight so that I can try driving the 40 to work tomorrow to see how the doors work out. I just have to remember to slam the door in the morning... I bet there is an adjustment for that.
Here's a sneak peek of what is coming up for my weekend project... Here's a hint.... SummitRacing had a great sale going on this week.
well… I’m slowly tackling the install of the Mosley ‘magic’ motor. About 2-week behind where I thought I’d be at this point, but having a lot of fun!
This weekend’s projects were getting the Sniper re-installed, Installing and bleeding the new master clutch/slave cylinders (including new SS braided line), flushing the brake lines with new fluid and getting the new Vintage a/c evaporator installed on the front of the radiator
This week I hope to get the radiator and bib re-installed, re-install the battery tray & battery and finish wiring up the new alternator (by-passing the external voltage regulator).
Still need to finish wiring and adding freon to the a/c compressor (inside cabin install complete)
Starting to see a glimmer of light at the end of the tunnel…
This week I hope to get the radiator and bib re-installed, re-install the battery tray & battery and finish wiring up the new alternator (by-passing the external voltage regulator). The
Nice cup holders. I put the same set in about a month ago.
Installed new fuel system including OEM Tank, sender, stainless steel fuel lines (hand made), Toyota fuel soft lines, Toyota clamps and later model fuel pump (with return). Adding the fuel return has solved the vapor lock hard start. Very happy to have this system done. Thanks again @ToyotaMatt for the fuel pump gasket and correct bolts.
Isn't that it?
So, did it pass your partner's inspection?
@Living in the Past thanks for checking. The spacer has a gasket on each side making it simple to install with FIPG. This version (spacer with gaskets) has Toyota Part # 90923-06010.
