And cleaned the contacts on top of the tank and guess what...my fuel gauge works now! Added 5+ gallons of gas...no leaks in a 20 mile test drive. No gas smell in the cab. Painted the tank cover and will reassemble. Very pleased with a couple of simple fixes!
Test fitted my rebuilt diff! Broke off one of the carrier retainer bolts and had to drill/easy-out, so disassembling the existing rear end while waiting for replacements. Lesson learned: Make sure the threads are chased and clean in the carrier caps BEFORE assembling the diff!
Another fun project finished up, aside from wiring it up and spooling the cable. Haven't decided on the cable type yet, synthetic or cable, any suggestions on the type of cable for a winch that will get light use would be appreciated from the pros on MUD. If anyone has a quick diagram of how you wire the 5 pin plug, battery and albright pack they could post up I would greatly appreciate it. Electrical is not my thing View attachment 2954932 View attachment 2954933 View attachment 2954934 View attachment 2954940 View attachment 2954941
Just finished valve adjustment (Lord hope I did it right!)……. Small ‘rabbit-hole’ appeared and I had an ‘artsy-fartsy’ day! Cannot claim it came out as well as others but damn if I didn’t rub for hours….. painted the raised identifiers just because
*Full disclosure: I took the cleaned up picture in bright sunshine to make my work look as shiny as possible!
So you worried about driving it with the hood latches undone and removed the front wheel verses just hooking the latches?
I do remember once many years ago on a fishing trip running out of liquid refreshments. We thought about driving into town for more but somehow wisely didn't. In the morning we realize and bunch of camping gear including a trolling motor were stack right behind the back of the vehicle. Could have been a costly error on our part. This was on a Saturday night as well when sometimes the best judgment isn't used.
A few weeks ago after driving up to the ski hill I found both hood latches were still released from the night before, luckily there wasn't any excitement.
As I remember it was right the start of the 74 when the secondary safety latch was added. Thinking adding that feature to my 73. On my 68 hood which is not only heavy I glue thick duct liner to the under side. I forget once to hook the latches. At speed I noticed it bouncing. Pulled over and hooked the latches. For how would have to pop open would have probably hit hard enough fold the top into the windshield frame. My 73 obviously had that problem from a PO.
luckily since I purchases I have acquired a spare or tow 72-74 hoods.
I did learn something today kind of cruiser related. I was going to start a thread on the difference between the 1/79-9/82 theb40 series transmission hump and the 10/82+ transmission humps. Flipped the screen on my phone to get the pictures of how high the inspection cover is from the later style on a 82 tub. I couldn't figure out the background. Finally dawned on me when flipped it takes a mirrored image.
Makes it look like the transfer case shift lever is on the left side. Guess I will hold on that thread.
Restored a few 89620-60010 FJ40 1975-1977 Igniters. Everything was dismantled, cleaned and yellow zinc plated. Bolt by bolt. The hardest part was sizing and finding the 4mm x 10mm semi tubular rivet and sourcing the correct flag connector.
Restored a few 89620-60010 FJ40 1975-1977 Igniters. Everything was dismantled, cleaned and yellow zinc plated. Bolt by bolt. The hardest part was sizing and finding the 4mm x 10mm semi tubular rivet and sourcing the correct flag connector. View attachment 2957983
