- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,508
@thecrazygreek
“fuel line grommet”
I as well as MANY others could use one of them !!!
I have heard that the 4 speed is a better transmission than the 3 speed. Do you think that putting in a 2F with a 4 speed would lower the resale value?Keep it 3-speed, and F (or maybe 2F).
Frame crossmember clearance, at the drum brake, is an issue with most 4-speed conversions. Also, most 4-speeds have their output shaft splines and output gear chewed up, creating an oil leak, and maybe a worse condition.I have heard that the 4 speed is a better transmission than the 3 speed. Do you think that putting in a 2F with a 4 speed would lower the resale value?
Fit the FST frame from realsteelcruiserparts.net. First time dealing with this company and they have great customer service, very fast shipping and a quality product!
For those of you with a FST, does the rear soft top frame sit tight against the tub?View attachment 2183569
Yikes.Did a remflex manifold gasket...safe to say it was time.
Carb hold down nuts were all pretty loose, exhaust downpipe donut just fell apart, egr pipe to manifold only had one nut holding it up and gasket was crumbling.
Started up and sounded/ran better than it has since i've had it.View attachment 2184146
Thank youMine is an Ehsan top. If I understand your question, there is a U shaped bracket that holds the upright tight against the inside of the tub.
What is the origin of those headlight rings?
Nice!! Thanks for the pic. Nice to see it on a vehicle.
I agree with @Engineer8000 What rings are those? Thanks.
