Mounted the correct winch today from a CL find
That one looks to be in excellent shape for a pre-1980 8274, good find.
H41 peeking in the back hopefully i can mate it to an orion tc soon.
You will love that combo!
Which holder are you using and how is it attached to the rack?
Ive been looking at this, but its designed for there rail system and not sure if it would work:
Double Jerry Can Holder - by Front Runner
This double Jerry can holder offers a smart no rattle no wear solution. Transport much needed fuel on any adventure or the path less traveled.www.frontrunneroutfitters.com
View attachment 1948348View attachment 1948349
Mounted the correct winch today from a CL find, H41 peeking in the back hopefully i can mate it to an orion tc soon.
Yes you are correct took me a while to find this one came from idaho CLCongrats. Seems like they’re near impossible to find these days.
Torqued the manifold nuts, installed a couple of screws on the ends - I know, it is like macro-brew out of a can if you are using Hillman hardware - see image. Then I spent a good hour or so, with the grinder, making the Aussie header's flange not rub against the 2F insulator plate. Installed the my newly rebuilt carb and discovered that the accelerator pump boot is already cracking. Then I had the idea of treating the OEM valve cover gasket with a bit of motor oil so that it won't get stuck on the head; the only issue was keeping it in the groove while I get the valve cover back on - it worked after I stretched it slightly so that it was closer to the size of the valve cover. Then I put the accelerator linkage on and topped it off with the air cleaner. Nothing but details the whole day, cleaning this, trying on that, finding screws that were lost two owners ago, using a re-threading tap because the air cleaner hasn't been properly fully installed on the engine for quite some time.
I've apparently underestimated demand for these stickers. Wait list is filling up quickly. Please see details in my Small Business thread - Wait list filling up - Repro Toyota sticker for FJ40 rear sillSold out again. I doubt I will do another batch, but it could happen if there is enough demand.
Bought a new set of hinges and installed hinge pins from @SMG ...now, ready for some paint.
I was going to buy some 1/4" cast aluminum and fab one. I don't think that I want the thin kind that are to be sandwiched between the exhaust manifold. Can I buy one from Cruiser Outfitters? The intake manifold is cracked on one side. Maybe I can score a better ('75 federal spec.) intake manifold?Do you have a heat riser block off plate? Looks like you need one... I spy a crack.
The stock one is still available via Toyota, just got one yesterday.I was going to buy some 1/4" cast aluminum and fab one. I don't think that I want the thin kind that are to be sandwiched between the exhaust manifold. Can I buy one from Cruiser Outfitters? The intake manifold is cracked on one side. Maybe I can score a better ('75 federal spec.) intake manifold?
Where can I get a decent accelerator pump boot?
