nabbasi
I test fit my radio. And Watson QC’d the new mat.
You sound like a Millwright. They are very acquainted with the BFH.I was hooked on rocks. Beat them back in place with a BFH
Odessey makes great full lead batteries. I have run one in my boat for over 5 years.Some from a local cruise club was kind enough to come over and help troubleshoot. We hooked up his heavy duty jump pack directly to the starter and it fired up immediately. Looks like I’ll need new battery cables and a better ground.
Battery is a brand new Odyssey extreme battery with 950 CCA. It’s a group 65 because none of the group 31s will fit in the stock tray. Stoked that it runs!
I am checking on them now. I was going to go with Optima but the size that fits the tray does not have the recommended CCAs and sometimes it gets pretty cold in Wyoming.Odessey makes great full lead batteries. I have run one in my boat for over 5 years.
Check out the Optima Marine battery. It fits the stock tray and has more CCAs. I have used one for my 12HT since 2017.I am checking on them now. I was going to go with Optima but the size that fits the tray does not have the recommended CCAs and sometimes it gets pretty cold in Wyoming.
I know what you're saying... I stood behind her just to help her up if she needed it. She made it.. but not like her or I did back when we were younger...Perfect @Toyjoy. Tried to take my wife for a ride to dinner a few months back but she couldn’t get in like she did back in ‘74. I grip the steering wheel and pull my self across the seat, she can’t do that on the passenger side... Took the Chevy instead
The Cummins installation guide recommends 850 CCAs and everything in that rating or higher is larger then the tray. I can modify the tray for the length. The marine battery looks like a good choice with a winch and lights that connect direct to the battery.Check out the Optima Marine battery. It fits the stock tray and has more CCAs. I have used one for my 12HT since 2017.
This is the battery I ended up with Odyssey. It has 950 CCAs and the length fits in the stock tray. I wonder if the angled edge on the long sides of the battery could be shaved down to make it a better fit.The Cummins installation guide recommends 850 CCAs and everything in that rating or higher is larger then the tray. I can modify the tray for the length. The marine battery looks like a good choice with a winch and lights that connect direct to the battery.
I was looking at that one and I wonder what the dimensions are on the bottom because I do see that it tapers down. So I am assuming that dimensions shown are the larger length and width at the upper section. I did ask Odyssey for a recommendation but have not heard back from them.
I moved the tray tight to the fire wall where the heater fan motor was and rotated it 90 degrees and clear my turbo.
Would you post a photo of the battery mounted in the tray?
