Nice! So I'm curious, what the PSI readings pump on: Engine off? idling? and 5 minutes after shut down?^^^^^
Fits easily under the engine cover if anyone wants to retain that. It's not a big unit.
That was actually my plan before I even ordered. I wanted to see how it went together first. Even with my carpet mocked up, the plastic flap still hits the latches. All parts would need to be recessed for the flap not to catch. I'll see what I can make happen tomorrow.Furniture sliders? Why not correct what the manufacturer should have done and countersink the holes and use some flat head cap screws?
On my way there I captured the very unfortunate rollover accident during an Arkansas National Guard convoy. Luckily no injuries. How do you flip a humvee? I have no idea...
Wonder if they eat crayons, tooEasy: 'National Guard'.
Wonder if they eat crayons, too![]()
put in a Sherpa 4x4 12k winch with synthetic, fresh front diff bushings sitting in a box waiting for a free day.
Nice work- whats the operating temp range the gauge is rated for? Will it loose accuracy to engine heat and hold up to under hood temps?Installed a Fuel Pressure Gauge (permanent fixture).
When traveling I don't have a lot of tools with me (just basic emergency stuff) and it can be hard to diagnose a fuel pump/fuel pressure problem. Since a connection to the fuel rail on a 2UZ-FE is right up front (unlike the buried one on a 1FZ-FE) I thought I'd just install a gauge there and not have to carry a tester. You could as easily install just a plain adapter.
I have the original banjo bolt in my tool kit in case I ever spring a leak with this set up.
To begin with I noticed the hole in the OEM Banjo Bolt was larger (and also chamfered) than with my adapter....so I remedied that by enlarging the hole and chamfering it to match.
Then using new crush washers I installed the adapter (Banjo Bolt w/45° Elbow).
Next....the Pressure Gauge itself:
And then testing the unit and checking for leaks
Could it be the Iggee's?
Gimme dat blue boiReplacing side cargo window gaskets and trim to stop a water leak. I like the work view though! View attachment 2606298
Curious what the actual perks to these are, given they don’t provide any adjustability? SPC says they’re stronger and have one bushing that allows “more flex” than the OEM arms. Any proof of this?SPC rear lower control arms
No proof whatsoever that I know of. They were cheap, I didn't want to run stiff aftermarket bushings, it sounded like a pain to resize holes for 80 series bushings, and it didn't sound like adjustable lower arms had much benefit. My understanding was that adjustable upper arms were more important. I talked to someone at cruiser outfitters a while back and that was the feedback that I got, although that was a while ago so I may be remembering incorrectly.Curious what the actual perks to these are, given they don’t provide any adjustability? SPC says they’re stronger and have one bushing that allows “more flex” than the OEM arms. Any proof of this?
I just took the first drive, and my rig feels so much more planted! The old rubber was pretty cracked, but I'm shocked what a difference it makes under acceleration and over bumps.No proof whatsoever that I know of. They were cheap, I didn't want to run stiff aftermarket bushings, it sounded like a pain to resize holes for 80 series bushings, and it didn't sound like adjustable lower arms had much benefit. My understanding was that adjustable upper arms were more important. I talked to someone at cruiser outfitters a while back and that was the feedback that I got, although that was a while ago so I may be remembering incorrectly.
