Perfect fitBuilt a storage box for the back of my truck. Still need to add the struts and thinking about whether or not I want carpet on it. Overall, pleased with it and now I can put all the loose items in the back out of site. View attachment 1242806
I have been known to baffle. But if that photo baffled you, then the sunset photo shoot that directly followed the door enclosure photo/test (in order to properly test stock 80 series key fob working distances), will surely baffle you. The test results were inconclusive....but the sunset was amazing!
Even my jokes are too tech!She is making a joke that she took photos sitting with the 80 rear door open and just wanted to share with mud. Lol
And yes...Harrop/Eaton E-Locker with matching OE magic dial in full effect!!! Love It!! Couldn't have done it without @NLXTACY and @Qball
I have to clear mine by the hour![]()
Actually it looks like the rust started in the wheel well, not from the interior. The mount looked fine from the outside, all the rust was hiding behind the undercoating.
It's going to be challenging to repair because I want the seatbelt mount to be solid. I'm just glad I found it this way and not in a accident.
I'm far from a rust expert so I will defer to your judgment. I just can't wait to get it fixed, the old license plate I have wedged in there to keep debris from being launched into the cabin isn't going to cut it for long.I disagree.
While the rust "erupted" in the wheel well, the pattern pretty clearly shows an "inside out" rust pattern.
I'd almost bet something was pressed against the metal on the inside of the body panel, like a rag or piece of carpet, (or mud?) that held the moisture there long enough to get it started. Or maybe there was something perforated there.
In fact, I'm looking at something that looks like missing paint in the picture; almost as if the protective coating didn't take completely on the metal.
Was windy when driving today and noticed my hood was shaking. Pulled over to make sure it was latched and it was. Why is it doing this? It is "lifting" up a solid 1/2" or so.
You realize there is this thing called "incognito window" right?
Does that battery switch fit the opening without cutting? I've been trying to find dimensions on it, but every time I search blue sea switch, it brings up the big dial. I'd like to run it vertically where your locker switch is with a winch switch above it and Im afraid it will either touch, or look out of place.For once in my life, I took the path of least resistance and used the switch that comes with the Harrop for my rear locker. Turned out nice IMO. Spot next to it is reserved for the eventual front locker.
All. This is tech. If you want we can close this thread and you can continue your conversation in chat. That has always been the rules, anything that isn't tech gets booted to chat or deleted.
Go for it.All. This is tech. If you want we can close this thread and you can continue your conversation in chat. That has always been the rules, anything that isn't tech gets booted to chat or deleted.
