Helped out @Qball put the OEM snorkel on his LX. Much more work than expected for the OEM install especially without instructions. Ugh. Install looks good. Birds nest does not.
View attachment 1012914 View attachment 1012915 View attachment 1012916 View attachment 1012917 View attachment 1012918
nlxtacy how do you like the way its made . What makes it water proof between the plastic part on the truck and the snorkel. Is there a tight seal where they meet .Helped out @Qball put the OEM snorkel on his LX. Much more work than expected for the OEM install especially without instructions. Ugh. Install looks good. Birds nest does not.
Mounting looks solid.
Any advantage with OEM over Safari?
What Phil said... I'm curious about the difference between the OEM and Chinese Dorkel...
The bird nest looks like darth vader is sitting on top.
The force is strong with this one.
The force is strong with this one. I easily gained 15 HP and 2mpg. In all seriousness the lower rpm does feel a little better.
I've now helped install a chinese, two Safari's and now the OEM snork. All I need is to do the IronMan and I think I would have installed all possibilities.
Fitment- OEM and Safari are close to tied but I give OEM an edge because of the extra foam and the brace for the top of the snorkel head.
1. OEM
2. Safari
3. Chinese
Finish- OEM still edges out only because of the bird's nest design. If you aren't using it then OEM and Safari would be tied. The OEM and Safari feels and looks near identical to each other. Chinese, well I think everyone is already well aware what I think of the Chinese snorkel.
1. OEM
2. Safari
3. Chinese
Installation- Safari gets this one only because the single large hole and studs are easier to deal with than the shaped hole for OEM and that there is a little more room for error with the Safari. Chinese only barely beats out OEM because of the lack of instructions or the instructions just sucking ass. The OEM took longer too because we had to figure out bolts.The Safari you need long skinny arms to get at the two nuts. With OEM you just need access to install the fender tube. Everything else OEM is attached via 1/4" rivets. QBALL had to get an industrial rivet gun to even use the larger rivets. Another advantage to the OEM is you do not have to remove the air filter canister.
1. Safari
2. Chinese
3. OEM
Honestly what makes the OEM good is the fit and finish but the large bird house thing on top makes it look stupid and is likely 1/2 of the cost. I could definitely see going with OEM tube and a Safari top intake.
