So as Captain Quint from Jaws said “Here’s to Swimming with Bowlegged Women!” Of and
to the best, most knowledgeable (my opinion at least), and most patient teacher out there
@Malleus. He spend half the day exchanging texts, pictures, and probably close to two hours on the phone helping me track down these issues.
This is going to be long and two parts so here it goes.
I had two obvious problems from my first start and the few starts there after. This first problem was that my key would not turn to the off position when the battery was connected but turned and came right out when I disconnected the battery. The second problem is there is a strange misfire, and immediately I am thinking related to the injectors. More on this one in the second post. So, we started with the key and ignition issue because I really did not want to keep hooking and unhooking the battery. That means I needed to pull the dash to check the key interlock solenoid. Once the dash was apart, I was able to test the solenoid and I was getting inside the range (17 ohms) on the resistance. Next, I grabbed a 12 volt battery I had from my deer trail cameras and some alligator clips and tested the operation by applying power across the two pins in the connector. The solenoid clicked as expected. We can now eliminate that as the problem.
Next, I decided to test the shift lock solenoid which is under the shifter, so the shift console had to come out. I did not get a resistance inside that range, but when I applied 12v power to the two pins, it operated as expected. I tested this solenoid because I can take the shifter from park to L and back without every hitting the shifter button on the side of the shifter. So I may need a shift interlock solenoid.
Next I moved into checking that I had resistance from the key interlock solenoid to the wires that came to the shifter for the computer shift lock control module. I did get continuity as expected on both wires that I needed to test. Next we pulled the cover off the shifter lock module. I pulled the circuit board out and after a good inspection, I found the diode D12 was burnt. So, I also need a shifter lock module. So, if I leave the key interlock solenoid unplugged, I can still remove the key and not have to keep unhooking the battery while I get the rest figured out and get parts ordered.
Also, I had a Center Diff Lock button sitting on the shelf, so I changed it out with the button that was there, but had Diff written on it with a printed label. And I pulled a ton of useless and unused wires out from under the dash while I was in there.
