Broke off a rear bump stop bolt in my frame.
I did almost the same a couple of weeks backBroke off a rear bump stop bolt in my frame.![]()
So frustrating. I knew it was a possibility and was going slow and dousing with PB as much as I could. Broke off anyway. Ugh.I did almost the same a couple of weeks back
But mine was the front bump stop![]()
Getting my rebuild harness adjusted and I found that one of the wires pulled out of a connector for one of the fuel injectors. I extended the wires so it is not in danger pulling the wire out again and got everything re-installed. Also, put the last coat of the clear coat on the valve cover. I don’t think it turned out too bad for a rattle can job and my first attempt at something like this. Last, I got the alternator and distributor back in as well.
Also cleaned sunroof drains and installed some new speakers in the dash (already did the front and rear doors).PCV valve on the 96 View attachment 4124626
How does wild turkey taste?Finally got to use the 80 for what I bought it for. Great morning in KY and some happy friends.
How does wild
it’s great fried in nuggets or marinated on skewers and grilled. There is very little fat so you have to cook it fast and not dry it out.How does wild turkey taste?
That’s a fantastic profileFinished up a winch bumper I’ve been working on.
Thanks! Tried to keep it tight, also light enough I can install myself with the winch mounted.That’s a fantastic profile
Just picked up a 1997 FZJ80. The black coating on my gutter trim along with the window seals / trim is chipping off. Do you recall the part number for the gutter trim with the black coating?Thanks!
The original gutter trim was looking aged and it was bent in a couple places along with the black coating chipping off. New ones are really a nice improvement. The cost of the gutter trim isn't bad, but since it comes in a 8' box the shipping makes it $$$. I ordered them through the dealer and that helps a lot with the shipping cost.
I used Carpro Perl on all the black trim and paint between the windows to darken everything, reminds me I need to coat my roof rack next.
