Got 35's finally! Going to yank off my wheels today and have the 31's taken off Monday to install my Apex RPV's and then get the new tires fitted back on
Also picked up a Bulldog 48" high lift jack, just need to finish up my DIY tire carrier and I'm ready for fun in 2026
I did Absolutely Nothing!
Happy Trails to all my fellow 80 series addicts...
In a few, cutting off the factory hangers for the long-gone running boards. Bought it that way... hangers but no running boards :rolleyes:. Need to prepare for sliders this summer. Easy job.
Based on what ? just curious
To me it looks like the front axle is at full droop as well. Once that axle has any weight from the vehicle isn't the slip joint going to bottom out?
OEM flange distance is 31.125". With the (3L) is now measured 32.375" from the 3.5" lift and the longer Rad arms (L). With spacer now I can get same engagement
The angle on the driveshaft looks off a bit, may give you some vibes. What are the angles between the shaft and face of the u joint?
Could be the picture angle.......I had the Delta regular 3 and swapped it with their 3L for plans to go bigger tires. Test drove it and no vibration at 80mph. If 4" lift perhaps DC shafts is needed.🤙
I do my fair share of crawling but not as hard-core as some of you guys. The spacer brought the DS position back to as before. And with the 3 regular, i haven't experience the bottoming out just yet.🤞
