Steering wheel re-wrap looks amazing. Who did you have do it?
I'm stumped on a part. The rear door wire harness is "clamped" in place as it rises up to the window control switch, but I can't find the fasteners on any diagrams.
Does anyone know what these are?
So you deleted the frame bumps and extended the coil ones? What did u extend them with?I finally got around to improving my rear articulation. My bumpstop drop brackets were a little too low and limiting up travel. My whiteline sway bar and adjustable end links were limiting down travel.
Frame bumpstop with extension.
New spring retainer/bumpstop extension
Frame bumpstop removed. Spring retainer/bumpstop extension installed and tested. The bumpstop is touching the axle but I still have up travel in the shock.
Up travel is a bit more than before.
Thanks! I got it from cruiserparts.net, and they sub it out to a local shop.Steering wheel re-wrap looks amazing. Who did you have do it?
More voltage to your incandescent bulbs that are focused properly.So, what does getting an upgraded harness with relays do for me? other drives hate me because it's slow and I stay in the right lane. It's a 91 with 3FE.
The frame bumpstops will definitely come back but will be much shorter. The spring bumpstops are too soft and squishy and could possibly allow shock damage if they bottom out. We drive the Cruiser on the beach and I've bounced off the frame bumpstops several times when fully loaded.So you deleted the frame bumps and extended the coil ones? What did u extend them with?
Who made the rear bumper? love the black diamond plate.
That’s a pretty cool color!Fixed some rust around the windshield. Getting ready to paint a new color black with olive green pearlView attachment 4029088View attachment 4029090
Thank you! Im really happy I nailed the color I was hoping forThat’s a pretty cool color!
It reminds me of the green sand beach on the southern end of the Big Island, HI.Thank you! Im really happy I nailed the color I was hoping for
Took the driver door panel off today to see why my door lock doesn't want to fully engage. Of course, up on removing the panel the locking/unlocking seemed to be working alright. I had plans to take out the actuator and possibly replace the motor, but it seems fine (unless I am missing something). I'm not certain yet if there is just some bit of friction between the rods and the door panel? I decided so far to leave things in place and just lubricate any hinges. Later this week, I'll be adding dynamat to the door and redoing the vapor barrier.
Unfortunately broke a tab off the triangular garnish piece by the rear view mirror. So I'll have to replace that.
Also has anyone reinforce the eyelets for the plastic door tabs? I was considering using aluminum tape to potentially reinforce some of mine.
ca glue is a great idea too! Part of me would like some custom door cards. But that is wayyy down the road.I've used ca glue for newer door cards and light costs of expoy for more worn ones.
