@WoodsmanNC I concur with @jfz80.@WoodsmanNC Where you at in NC? Looks like mountains. A 40 a 60 and an 80; you’d fit right in with ONSC clubhouse. Tagged you in the members section.
I’m a fan! FJC Steelies widened to 17x9 going on soon.
Yessir, mountains. I will certainly check it out. Been meaning to actually.@WoodsmanNC I concur with @jfz80.
For sure; it's all I run. I like the businesslike styling. I'm having a set made now in 17x8.5. Arms gray.You are going to like them. My 80 has the flares removed and they line up flush with the edge of the fender well perfectly.
Did you correct the backspace while you were at it?I’m a fan! FJC Steelies widened to 17x9 going on soon.View attachment 3195277
Just added to the front of the wheel.Did you correct the backspace while you were at it?
do you have more pics of your truck? I love the look. Might declare mine soon.For sure; it's all I run. I like the businesslike styling. I'm having a set made now in 17x8.5. Arms gray.
Finally got everything back were it’s supposed to be and the brakes feel better too.Was doing some troubleshooting on the brakes because they don’t feel right. Noticed the brake booster missing a nut and a gap. Can anyone send me a picture of their brake booster? Want to reference mine. Thanks View attachment 3190997View attachment 3190998
CarPlay is a much better solution but if you really like the retro look, I’m sure you can find someone to donate theirs….Awesome! Thanks for the info and now I have something else I want to add
Rant on ...
Car was reading 12 volt when idle, checked and the alternator was lose. 2 hrs of sweating, swearing and grumbling passed and i managed to get it tight again.
Now the bolt was too small hence whey it was moving, both belts badly worn and the genius who did the previous poop job replaced the 12 bolt tighting screw with an alen key one.
Battery removed got it running and took it to mechanic.
Rant off
Mechanic changed fuel filter, 2 alternator belts and currently fixing the exhaust (i smelled exhaust so found out another leak at the back)
That would work woth standard 12 bolt, car was out of spec. Even worse is that the alen key was badly worn.FYI, come through the LHS wheel well with about 20” of extension and you can easily adjust the alternator adjusting bolt.
Cheers
The leak is behind the coolant bypass tube and the exhaust header. The blue fizzer thing is a combustion leak detector. If test fluid stays blue you're good... probably.davidp14, would you elaborate/educate me briefly on your post? Top pic is thermostat housing? Which you thought mighta been leaking oil... Whats the radiator blue fizzer aparatus?
- Curious Ignoramous!
