FMC80
Two words: Aircraft Remover
What color are you going to paint it?Two words: Aircraft Remover
Not sure. I’m going to get it tanked and then store it until next year. Got any suggestions? Rainbow to show my acceptance and inclusivity?What color are you going to paint it?
Well, that'll be different for sure.Not sure. I’m going to get it tanked and then store it until next year. Got any suggestions? Rainbow to show my acceptance and inclusivity?
Absolutely hilarious.“and 4 dogs of varying intelligence.”
I would lol.View attachment 2814990Luck was on my side.. Crank bolt off with one bump of the starter and oil pump screws came out with zero issues… Maybe I should go grab a lotto ticket…!!
DIY wrinkle? I am pondering DIY wrinkle red but skeptical I will do a great job.Well, that'll be different for sure.
I like how the two I've done came out. The first was wrinkle black undercoat with gunmetal grey on top.
This one is just wrinkle black.
Under radiator support. More direct and clean. Just zip tie it in....2nd battery tray installed and PCV valve/hose replaced. Are you all running the battery cables in front of the radiator where the headlight harness runs, or the long way back to the firewall? I'm going to mount the isolator behind the 2nd battery tray fwiw
A 3 day weekend camping and running trails in the UP Michigan. Day one is a blast so far. Had to bust out the traction boards once and added the first pinstripes this LC has ever seen. It only took 30 years for an owner to care enough!
Aired down to 22psi for some beach driving.
The Mouth of the Huron area is worth the drive in the off season. Only 2 other campers here.
I'll be doing some paddling tomorrow and a bit more exploring.
what is the general iH8mud recommended air pressure for beach driving and other trail running?A 3 day weekend camping and running trails in the UP Michigan. Day one is a blast so far. Had to bust out the traction boards once and added the first pinstripes this LC has ever seen. It only took 30 years for an owner to care enough!
Did the same job just before world locked down last year. Mine came out easy too. White 80s got slightly better oil cover screws. Just one of the many benefits.Luck was on my side.. Crank bolt off with one bump of the starter and oil pump screws came out with zero issues… Maybe I should go grab a lotto ticket…!!
