Before n after
Admitting defeat isn’t the end.Ok, here we go. Was with a group of Jeeps out in Big Bear last weekend. While climbing the 1st obstacle at Dishpan, i heard some rubbing noise coming from the front of the engine bay...the noise was far too familiar, and as i get to top of the obstacle, i pop the hood and immediately noticed coolant all over the engine bay and dumping down from the bottom. The top of the fan shroud was missing a large chunk and the fan blades were damaged. The fan caught the top of the shroud, chewed off a large chunk of the plastic and put a large gouge between the top tank and the fins along the top....removed the fan clutch and broken shroud and the damage became apparent. the tubes were separated from the top tank all across the top middle portion and it was leaking out as fast as the water was poured in. I completed the rest of the trail pretty much with a dry engine, dumping water in every chance i get, and called AAA at the nearest gas station in town. Long story short, a cheap piece of plastic took out my Ron Davis Radiator. So lesson learned, replace the fan shroud if it is cracked or damaged. I have yet to confirm if it was a broken engine mount causing the engine to move up, but i had just replaced both of my front engine mounts and tranny mount not long ago prior to my trip to the Rubicon back in Aug. This is a costly $1500 repair that could have been avoided.....I will confirm if i have a loose engine mount or broken mount once i gathered enough courage to look at the rig again and start the repair process while waiting for the new Ron Davis to be delivered with a 8-10 weeks lead time...
@baldilocks..there.... i post it on MUD.![]()
Lets see the inside of that engine bay!Moonlight Stainless steel snorkel
Took her for a drive in the snowy mountains, a bit late in the year for snow but it was nice
View attachment 2804502View attachment 2804503View attachment 2804504View attachment 2804505
Great movie! My boy’s and I watched it many times back then…..Epic!!!!! I have always figured that if I ever make it to Australia I am definitely going to visit the snowies. That looks like some beautiful country.
If I could "dislike" this I would. That sucks!Ok, here we go. Was with a group of Jeeps out in Big Bear last weekend. While climbing the 1st obstacle at Dishpan, i heard some rubbing noise coming from the front of the engine bay...the noise was far too familiar, and as i get to top of the obstacle, i pop the hood and immediately noticed coolant all over the engine bay and dumping down from the bottom. The top of the fan shroud was missing a large chunk and the fan blades were damaged. The fan caught the top of the shroud, chewed off a large chunk of the plastic and put a large gouge between the top tank and the fins along the top....removed the fan clutch and broken shroud and the damage became apparent. the tubes were separated from the top tank all across the top middle portion and it was leaking out as fast as the water was poured in. I completed the rest of the trail pretty much with a dry engine, dumping water in every chance i get, and called AAA at the nearest gas station in town. Long story short, a cheap piece of plastic took out my Ron Davis Radiator. So lesson learned, replace the fan shroud if it is cracked or damaged. I have yet to confirm if it was a broken engine mount causing the engine to move up, but i had just replaced both of my front engine mounts and tranny mount not long ago prior to my trip to the Rubicon back in Aug. This is a costly $1500 repair that could have been avoided.....I will confirm if i have a loose engine mount or broken mount once i gathered enough courage to look at the rig again and start the repair process while waiting for the new Ron Davis to be delivered with a 8-10 weeks lead time...
You can dislike it. I just disliked your post for not knowing how to dislikeIf I could "dislike" this I would. That sucks!
He put them on just so you'd askWhat's the story with the 5-lug wheels?
There are plenty of easy roads around the park so a stock 80 will be fine to run around in. IIRC most of the moderate stuff has places to bail out around some of the more challenging obstacles. Use your best judgement and you should be fine.Speaking of upcoming camping, hoping to also visit Hidden Falls Adventure Park near Marble Falls, TX. Anyone familiar? I am new to off-roading, so I plan to just do some of the easier trails and avoid the crawling. Also this rig is my DD and I have zero armor, sooooo... Anyway, would appreciate any feedback on the park from those who have visited.
Probably swapped to 70 series hubs.What's the story with the 5-lug wheels?
Well sumb1tch! I never paid attention to it. I disliked yours for disliking mine for not knowing how to dislike!You can dislike it. I just disliked your post for not knowing how to dislike![]()
I really like the boxed braces on those but I'm having a hard time swallowing the silver step plates. Not sure, may need more picturesGiant box!
Shipping protection
Angels singing
Quick picture before bed
