Decided to take the axles off and REALLY do a serious job cleaning up the frame and axles before coating them. Loving this warmer weather!!
Smart move, I need to do this.Decided to take the axles off and REALLY do a serious job cleaning up the frame and axles before coating them. Loving this warmer weather!!View attachment 2668108
Helps to not be married or have kids, and also to not have a jobSmart move, I need to do this.
I do that twice a year!Decided to take the axles off and REALLY do a serious job cleaning up the frame and axles before coating them. Loving this warmer weather!!View attachment 2668108
Did you do new end links also?I feel like I just attended a gay pride parade with all these colors everyone has going on
I wish everyone would go back to black, suppose this comes with more cost. Prepping the sway bar front/ rear. More beefy bolting on...
Most the day spent scuffing up YZ and this awful blue to go black.
Wow you are low. I am all for big tires with little lift, but this seems pushing it. Maybe I'm wrong though how do you like it set up like this?The Lx needed a break from the Daily Duty Grind, so I loaded up the family then took a 2 hour drive South to Oceano Dunes. Took a quick spin down the beach & took a few quick pics then ate some Fish & Chips in Pismo. We could of done all that in the Honda mini van, but the cruiser was more fun, well for at least me. View attachment 2668367View attachment 2668368
Is noise a characteristic of these springs that requires rubber isolators to eliminate?Added some rubber spring isolators to quiet these down. They chatter quite a lot! This photo is the initial placement to see if it worked. It sure did. They are quiet now. I’ll probably re-install on the top coil, then every other coil for the first 6 coils. Thanks again @bajaphile for the solution! View attachment 2667473
DottoAndddd ordered!
DittoAndddd ordered!
Yeah, Ive been pushing the limits of how low can you go... in the end Ive lost the ability to go fast type off-road. Meaning I cant do bombing runs though terrain like I did with the 75mm Slinky set up. At empty ride height I have 4" of up travel, but once I get my adult size family & dogs get in Im like you see with 2" of up travel. Its super stable though...Wow you are low. I am all for big tires with little lift, but this seems pushing it. Maybe I'm wrong though how do you like it set up like this?
I think I remember you saying that somewhere else actually. Pretty cool to see all the info you have from all of the experimenting. Do you have any plans to go back to the "sweet spot?"Yeah, Ive been pushing the limits of how low can you go
forum.ih8mud.com
I did, everything both SB's. They were feeling a bit loose and one was spewing out grease, with the 30mm bars I wanted the entire set to be solid.Did you do new end links also?
Did you order oem rubber or that super bushing rubber?I did, everything both SB's. They were feeling a bit loose and one was spewing out grease, with the 30mm bars I wanted the entire set to be solid.
All super pro at this point outside the OEM SB end ties to the frame. Being a 30mm upgrade I was thinking the OEM wouldn't work? Wits end should really consider a 30mm mount and bushing set. The OEM SW mounts he has look nice. Unfortunately the rubber in the SP 30mm kit is all an ugly blue also and the SB axle end is a larger hole and includes bushing as well. I didn't realize this and not sure I'm liking that.Did you order oem rubber or that super bushing rubber?
Yes, that is the current PN.Is this still the good p/n for a 96 head gasket kit?
04112-66036
