How long does it take for one of you experienced mechanics to pull a 3FE motor?
So far I am about 7 hrs in. I think I will be at 12 - 14 hrs. Frankly I am a bit over my head and this is a lot of work!
Granted my LC is very crusty which adds some time.
Any tips for getting the big bolt off on the main belt drive? Also how to get the main belt drive off for that matter?
Now I have to go watch 24/7 Action and Stuck at Inskip for motivation!
You don't need to pull that off to pull the engine.
If you've pulled an engine before, you should be in the 7-8 hour range or less.
However, with all the corrosion going on there, taking the time to label wiring connections, taking pictures before disassembly, reading the FSM, and finding the right tools, yes, you'll easily be in the 12-14 hour range.
It's better to take your time and understand what you're doing than to blast through, rip everything out, than to try to figure out what went where when it goes back in.
You can do most of the engine disassembly on the stand, not in the truck.
Remove the exhaust pipe from the manifold, disconnect the wiring harness at each point (alternator, sensors, AC, etc.) Radiator hoses, heater hoses, transmission bell housing bolts, torque converter bolts, and engine mounts.
You'll need to support the front of the transmission since it looks like you're just pulling the engine.
Don't unhook things that you can leave intact. AC lines, leave attached to compressor and remove compressor off to the side with all still attached UNLESS it's already discharged and you will be replacing a lot of parts on that system.
Leave the transmission cooler lines (if the 3FE has them) unless a line is inhibiting you from pulling the engine.
The PS pump may be able to be removed from the engine and sat off to the side so you don't have to drain and refill all that system. Unless you're rehabbing that too.
If you haven't already, I hope you're bagging bolts and labelling where they go. That's a life saver later. Do a bag for each component. You may have 30 bags by the time you're done,some with only one or two bolts.
I once pulled an engine out of a 1969 Chevy K10 in under an hour. However, that was the third time in three weeks, so I had it down and all hardware was well lubed and all labelling was already done. That time was from driving it in to pushing it back out with the hood back on it.
The guy across the street wash still washing his truck in the driveway from before I started to after I finished.
Good luck!
