Now do the PHH just because. Lol. Good job though.
Those will be good sellers!!!I’m not proud of this but it was necessary for the time being.
This turbo truck lived in South Carolina for 22 years before I bought it drove it to the West Coast. Now I say this because rust is a crazy real issue for non-west coast trucks but I got lucky.
One of the things that eventually needs to be take care of is the roof rack residual rust. The truck is mostly perfect except for the rust on the OEM lame ass roof rack. So f’ing annoying. Everyone has to to deal with this at some level. Three of the legs were fine but passenger front shoes signs of rust under the paint. Boo. I’ll have to deal with that later.
For now I just need to deal with the existing holes where the factory rivnuts are in the roof. Each needs to be dealt with before the rain starts. I took the easy way out for the time being. I just used EXTRA wide button head screws with UV stable rubber washers. The ID of the washers need to go around the outside of the rivnuts because they sit proud of the roof. The flanged stainless bolts need to squeeze the rubber washer to create a positive seal to prevent water intrusion. It’s not super sexy but it absolutely solves the issue until I can take care of the rust at another time in the very distant future
View attachment 2423628View attachment 2423629View attachment 2423631View attachment 2423632
To those that have the machining and fabrication skill I Desperately lack. Is there a possibility to fabricate an attractive and possibly useful thin piece of metal and mold a rubber gasket that could be bolted in these holes and that would cover the entire spot left by removing roof rack feet? This would allow one to repair and mitigate any rust or compromised paint and cover up the small Repaired area.
Might even work for the rear Window dust spoiler and rack strips as well? Could Even be painted body color to make it far less noticeable.
pro tip, you can swap the upper and lower seat belt bolts if you want the top to be more flush or replace with theseFinally deleted the third row seatbelts. The passenger side bracket bolt was rusted so I had to cut it off, but other than that it was an easy process. I’m much happier now without those things in the way.
I also kept the belt assemblies so if anyone wants to buy them, let me know.
not only considered but actively working on it.![]()
105 box by Adam Tolman, on Flickrnot only considered but actively working on it.![]()
make sure to post a pic when you get them on!!! what back spacing did you go with? i know there was i think 4.75 and 5 something?Winner chicken dinner. They come with hub rings Aka hub centric as the center bore is 112mm (106mm).
I personally never buy wheels that require spacers/adapters or any modifications to make fit for my liking. Hope this helps!
Pardon Our Interruption
www.summitracing.com
Im probably going to put a fire extinguisher there and if I don’t do two, then I will maybe fabricate some kind of flashlight holder or something - but I dig that tip!!pro tip, you can swap the upper and lower seat belt bolts if you want the top to be more flush or replace with these
Love PFI Speed and wanted to stop by with my swap’d 80 one day when out in Colorado. Imagine my surprise when I got an alert for this video. Has got to be someone on ‘Mud!
-18 offset, 9.5”make sure to post a pic when you get them on!!! what back spacing did you go with? i know there was i think 4.75 and 5 something?
Great rack from the greatest state!this showed up on my doorstep from a little place called Michigan
i tried to take as many pictures as i could
very straight forward install and i couldn't be happier with the final product..... thanks Patrick ad bowfin Cruisers
