Couple of small things, but felt like huge accomplishments! First off, I installed some JDM spec rear b-pillar handles. Stupid easy. Found everything needed in here:
And secondly, I installed some IPF Lights that I had picked up from @cruiseroutfit. Lights are fantastic with the 100w bulbs in them. Wired up a decent switch, that fit in the center console with some, uh, light massaging. The wording lights up with the dash lights, and the upper logo lights up when it's powered on.
I’ll link it to the post once I find them... got them from Amazon...What kind of ambient lighting did you go with?
Keep us posted if one can catches more oil vs another!I installed a catch can on the pcv line awhile back, so now that my intake is squeaky clean I put another one on the breather hose. I figure this is where the crap comes from that dirties up the throttle body and cold start injector. Those are not the final hoses, it's just what I had laying around.
Well that would have been really coolAhh too bad. I have a spare fog light switch for 62's. The logo is rubbed off but it's a two position fog/driving light switch. Are those the IPF968s?
A cheap radio that has all that I need. Got it about 3 years ago. Took advantage of this beautiful weather
View attachment 2577527How does the "sleeve" (that holds the radio) attach to the stock mounting brackets?
Living up to your avatar for sure.Technically it's not part of my 60.. yet.. but tonight I made a block-off plate to cover the oil level sensor hole in the new oil pan. My engine doesn't have that sensor and I definitely don't need it in a 60, but as far as I can tell you can't get this pan without that hole anymore. (This is going on a 1HZ)
There are compatible block-off plates for sale online that are marketed for 3sgte and 1fz-fe's but they all seem to use an o-ring instead of the Toyota compression style seal. At least on my oil pan, the plate that the sensor bolts to is not sealed to the sidewall of the pan so if you don't have a seal that compresses against the pan, it would almost certainly leak.
View attachment 2578135View attachment 2578137View attachment 2578145
Nice work D. OCD is is top notch, even the bolts are in perfect alignment.Technically it's not part of my 60.. yet.. but tonight I made a block-off plate to cover the oil level sensor hole in the new oil pan. My engine doesn't have that sensor and I definitely don't need it in a 60, but as far as I can tell you can't get this pan without that hole anymore. (This is going on a 1HZ)
Tail lights and dash lights are on the same fuse.Finished putting on my Ironman lift (all but the rear shocks, bushings were too big). Its funny how a 2 inch lift will actually lift a 250k mile rig 4 inches.
Now onto figuring out why my taillights and dash lights don't work. I'm suspecting a bad taillight relay.
