I was thinking the same thing, also I believe the 70's came some something similar.I believe that is a factory suspension seat frame. Not a US market offering, being from Canada may explain it. HDJ61 JDM has a VX designation so maybe they were swapped in.
So this is still a manually operated seat as the original 60 rails are integrated into this system. Closer inspection shows the cutting and welding done. Casey, I have some 61 suspension seats and these are completely different. The mechanics on this one uses a single rubber bladder (similar to an air bag suspension kit) manually pumped (lever on left side) up with some type of shock on the right. The frame is a heavy duty scissor style set up. The air line has a leak and have not been able to pump it up. Will post the driver side which has a true suspension seat (non Toyota) that’s been modified to work with the stock seat. As said earlier, someone was very creative and did some good fab work.Been working on a HJ60 that originally came out of Canada. Removed this very View attachment 1730254 View attachment 1730255 View attachment 1730256 interesting seat frame. Anyone ever seen something like this in a 60? Someone put some thought into building this.
No doubt Laird , that would make me crazy..... looks like a public swimming pool .HOLY CLUSTER F..K !!
If you haven't already replaced the gasket, make sure you get the old gasket material out from way up in the corners. My '82 FJ60 oil pan was leaking from the corners and that was the issue. The PO/shop didn't take their time cleaning.Could not have been easier. Drain oil, place jack w/ block of wood under pan, remove screws (most barely more than hand tight) , lower jack and HELLO under belly. No prying or pounding necessary.
Gasket peeled off. Some bit of metal noted although I HAD installed an aftermarket fuel pump that was a smidge wrongly snapped and it’s arm got torn off so.... are the bits just from it? They appear like s***ty junk metal. Bearing caps must be thinner and a different shade?
Look how sparkly clean she is!!! I only gave a slight tug and it cameIf you haven't already replaced the gasket, make sure you get the old gasket material out from way up in the corners. My '82 FJ60 oil pan was leaking from the corners and that was the issue. The PO/shop didn't take their time cleaning.
Look how clean! I only had to tug it free and nothing was stuck. All four corners, easy peasy.If you haven't already replaced the gasket, make sure you get the old gasket material out from way up in the corners. My '82 FJ60 oil pan was leaking from the corners and that was the issue. The PO/shop didn't take their time cleaning.
Woot! If you need guidance, ring me.Just received a knuckle centering tool from Jason @reevesci
Some local mud guys and i pitched in to get it. Makes sense to have one handy. View attachment 1730835
