What did you do to your pig today?
Have some leaves been pulled?
Edit: Maybe not. I think my spring retainer (or whatever that is called) looks similar. But nonetheless, your spring pack doesn't appear to be as arched as mine. Hard to tell though unless they were side by side.
No, that was supposed to be a new OME HD susp. It may have been , but with weight its almost flat, also not as beefy as rear
When I put my new ome on the front it went flat. I took one spring out of my old pack and added it l, pretty much like a add-a-leaf did 3rd spring from top and it was way better. When I first pulled the pack apart I could hold the tension with my hand to get the pin out after adding a stock spring I had to use a clamp to put it back together. I went medium though not hd. Measured from ground to fender after adding the ome springs and adding the one stock spring it set exactly 2” taller I havent checked after a month of driving to see where it sits
Short shackle issues and too fine of a line between ideal and less than ideal.
At 90° shackle angle you have 100% "spring rate" and past 45° shackle angle you lose all spring rate until the shackle inverts and binds on something else.
In a perfect world lets say 67.5° was ideal at ride height and we never got to 45° at full compression then we could count on a constant spring rate within a small margin. The wider that shackle angle gap is the less constant that spring rate is and the harder is is to get right. Nobody has done anything wrong or making bad kits for the Pigs and I don't believe making the spring stiffer "preventing movement" is a great answer as ride quality and drivability suffer with a stiff front suspension.
Longer shackles are the answer but as I said before not as easy as it sounds.
I experimented with this when I built my pig and I added 50 lb bags of sand one at a time measuring shackle angle.
The design of the factory configuration was barely adequate with a factory length mainspring, add a longer main leaf and it's a hot mess in a hurry.
I registered my 1969 pig for SAS #9 in August in Ouray, CO. I see that there are five other pigs registered also. One of them is @gonzopancho who is also a vendor for the event with BIO. @mike_az is on the waitlist.
Who else on here registered?
