TJ - thanks for the links and sub links! I had found a speedo link with pictures maybe two years ago and bookmarked it, but clearly there are more insights. I have found the search capabilities of MUD lacking…or maybe it is me that is lacking! I find more on MUD using google.
When I first finished the restomod of my 1969, one thing that did not work was the odometer. The 1/10ths moved but that was it. The speedometer part worked great. I have the older screw in connection (see pic) and since I put in a 2F, H55F, and split transfer case, I had a cable shop make up a custom speedo cable with both correct ends. Next step was to get a mechanical converter to register the correct speed since I have 33” tires. Anyway, I bought a second gauge cluster thinking I would open that one up and play with the odometer mechanism to learn on. Well that gauge using the drill test worked for both speed and odometer. Two problems: 1) it was crusty faded 2) it had the newer style connector for the speedo cable so would work with my cable.
So I put it on the shelf for another day. Now that my original gauge is acting up, I pulled it off the shelf again to see what options I have. Cleanup the crusty working gauge and get a new speedo cable OR tear apart the original gauge and see if I can get both the odometer to work plus fix the weird speedometer noise and fluctuation where the needle bounces to 75 periodically.
I am also thinking about putting together pictures and a master thread for gauges sort of like the bottle jack one on MUD.
