4 speed FJ40s ('74,5,6) had PTO gears, but only until 1976, when the PTO was discontinued as a facotry option. I had to add a PTO gear to my '78 FJ40 xfer case and remove the spacer put in its place.
I installed a PTO winch from a '76 FJ55, and the pillow block is located at a different place on the driveshaft and will not bolt up to an FJ40. I had adriveshaft shop cut it apart and remove the pillow block. The shaft was made into a 1-piece shaft. It has worked fine for many years. (In retrospect, I wouldn't do it that way now). My '76 FJ55 PTO gearbox has a front and rear output flange.
