Steering Stabilizer
do you know how much shipping is going to be? I saw those and then saw the OME's at man-a-fre for about half the price. OME is going to be installed tomorrow.
Ahhh, nooo!
Get the one that CCOT makes. It's around $100 and bolts to the stock location. It's beefy and has no needless spring.
LikeArockCruzer said:
Has any one ever used one of these steering stabilizers to help stop steering box wander?
I wouldn't buy a steering stabilizer to stop wander. I'd buy it to keep me from breaking my thumbs when I don't hold the steering wheel right.:doh:
A curb at 25mph has the same effect.:D
If you have wander it's most likely not going to be fixed with a steering stabilizer. Though I believe they are a needed part for manual or power steering.
roddie1154 said:
has anyone ever put on rancho's steering stabilizer? is it any good?
yep - put on their highest end Rancho SS about 6 months ago and it worked awesome. I even wrote about it here in tech that I had great results with it eliminating wander, darting and such. There will be plenty of guys (as you can already see) that will chime in about "it is a band-aid.. blah blah blah" every time the stabalizer question is raised - but to answer your question direct, I found the Rancho to be worth the money and immediate results in my case.
RS5000 is there high end stablizer.
The actual part numbers vary based on (1) the attachment style of brackets on your rig and (2) the length of SS you need, so I am not sure my part # (RS5402) will work for you. You can call Rancho direct and talk to their tech department and have them help you determine exactly what you need, but double check from a 2nd source. In the end, I bought from these guys as no one could touch their prices (I also did shocks at the time) and they were super helpful: www.sportztrailers.com
sorry bro, I canot answer for sure. I believe mine to be stock also (but some of the stuff the PO did has proven me wrong before). I also have larger tires than stock and a lift and larger shackles and such, so.... I would just call either of those 2 - at least Rancho direct as that is their job - and tell them as they have a book on all the rigs and/or can ask you and get measurements off your rig and narrow it down.
Spend the $100 you'd be spending on a stabilizer on a new set of spring bushings, tie rod ends and a front end alignment.
I run 35" tires and NO steerign stabilizer, and I can drive the truck with 2 fingertips at 70mph
