MatthewMcD
- Thread starter
- #41
OK, I'll ask about it. They don't ship until tomorrow.Both of those and what the knowledgeable people you bought the kit from say.
Mine needed exactly 4* on my old setup and my D’bagginson’s put me at the same place initially, measured for 4*.I had them on a 4” lift but don’t believe you need them on a 2 1/2
Also, one of the best things I did for stability in steering aside from toe in which you’ll need to address as well.Mine needed exactly 4* on my old setup and my D’bagginson’s put me at the same place initially, measured for 4*.
Consequently, my 62, which was a lift, needed exactly 4* as well.
You think it's needed on a 2.5" lift?
@cruiseroutfit is that something you guys stock?
Well s***!Absolutely, and they are generally included in the kits where necessary. I'll take a peak at your kit when I'm at the shop tomorrow.
2° Aluminum (made by Old Man Emu)
Aluminum Caster Shims (Pair - 2*) - Fits 4x/5x/6x/7x OME Leaf Spring Applications (OMECW2)
Steel Caster Shims for Toyota Land Cruisercruiserteq.com
2° Steel (Bolt-In)
Steel Caster Shims (Pair - 2*) - Fits 4x/5x/6x/7x 2.75" Wide Applications (SUSCW2PAIR)
4° Steel (Bolt-In)
Steel Caster Shims (Pair - 4*) - Fits 4x/5x/6x/7x 2.75" Wide Applications (SUSCW4PAIR)
6° Steel (Bolt-In)
Steel Caster Shims (Pair - 6*) - Fits 4x/5x/6x/7x 2.75" Wide Applications (SUSCW6PAIR)
Thanks Kurt, I shot an email over to Chance asking the same question.Absolutely, and they are generally included in the kits where necessary. I'll take a peak at your kit when I'm at the shop tomorrow.
2° Steel (Bolt-In)
4° Steel (Bolt-In)
6° Steel (Bolt-In)
Now you’re just flirtingI also have extended shackles
There is a very simple way to measure for this that may seem like voodoo at first. I’ll bet we can even anticipate what you might need based on where you are now and what kit you’re getting.Thanks Kurt, I shot an email over to Chance asking the same question.
Let me know.
on or off road?There is no better riding fj40 suspension than the Dobinsons IMS
Head and shoulders the best.
Both in my opinion.on or off road?
Looks like something else I need to purchase now. Good thing it will be an easy install. Will I have to change the pin as well?Sure need something like 4° shim with extended front shackles
YesLooks like something else I need to purchase now. Good thing it will be an easy install. Will I have to change the pin as well?
This s*** gets better and better. Look for my cruiser in the classifieds
