thebigredrocker
Background:
1976 FJ40
Stock 4 speed and transfer case
Downey bell housing
Centerforce clutch
Chevy .327
2" EMU lift
Inside, Underside & firewall Line-x'ed
Saginaw conversion planned
Previous restore #1 did motor mounts & transfer crossmember for a sbc. I'm #3 to attempt this restoration.
I found out the motor is a bit too far forward when I mounted the Radiator. I purchased a Flex-i-Lite slimline fan to address that. I'm finding more issues now as I progress.
The issue I just discovered is the shift tower is under the heater & not even close to lining up with the tranny cover holes. The measurements that I've determined would allow for the shift tower to clear the heater and align with the tranny cover holes is 3 1/2"s.
So far I've been trying to do everything as correct as I can figure out. Someone suggested I cut the recessed firewall and make it flush to move the heater forward. I'd also have to agressivly modify my stock rhino lined tranny cover. I can see this may be a possibility but it makes my gut churn to consider hacking things up.
Here's what's swirling in my head. Get some different bolt on motor mounts. If I can get firestein motor mounts would they reach up far enough to keep the motor from sinking any lower in the frame? Do I need to have Transfer case mounts welded on or are there some I can bolt on? I would like to leave the tub on if that's do-able. Can I hook the engine to my cherry picker and support the tranny with a rolling jack to slide the drivetrain into position? I just received a saginaw mount kit & sweet custom bumper from 4x4labs. I have spoken to a local mobile welder who said he would weld that stuff up for me. So if weld on motor mounts/transfer mounts are the way to go I could ask my local guy if he'd be up for that too. I know that could get spendy though.
Issues with a 3.5" move that I can see are:
-passenger side ram horn hitting firewall. If 3.5" back is determined by my MUD mentors to be the way to go, how would I resolve lack of room here?
-passenger side valve cover hitting firewall (I will not hesitate purchasing different covers if the exist)
Is there a bellhousing that would allow me to move the motor back less yet shove the tranny into a better position?
I live in Washington State. I have entertained the thought of finding a Landcruiser shop nearby to get me over this hurdle.
I know this is alot to ask and I am greatful for all kindness extended to me from the MUD community.
1976 FJ40
Downey bell housing
Centerforce clutch
Chevy .327
2" EMU lift
