Or just use a smallish blow up ball. Pretty sure there's a joke in there somewhere.....Looks like ma
Looks like maybe one version for "out in the wild" with a tennis or nerf ball that is more portable and another, with a larger ball, for home use.
I tried that with the pool noodle. It creates a void between the two, if you're talking about the front to back center braces. One pool noodle over the main cross bar above the driver's head isn't quite enough.Why not put some 2” pipe insulation over the center bars. That may add enough slope from the center.
Park on a slope.
what?
Slight thread derailment-The idea of fiberglass snow stakes popped into my head, though not sure how you'd secure them to the cage.
You could likely sew some small pockets into the bikini top that would accept an end of the snow / tent stake. If the pockets were spaced such that the pole had a bit of spring / tension to it, I wonder if they would act like ribs and add just enough structure to prevent so much flapping? That may be an better use for them than for my original suggestion to @woytovich.Slight thread derailment-
I don’t have the pooling problem- I live in a fairly arid environment. I wonder if the snow/tent poles would help with the flapping on the family cage. Most days I don’t mind it, but occasionally it’d be nice hear myself think at 60mph. This also seems like a simple solution to the pooling issue, possibly permanently mounting them. I’ve also considered a rigid “bikini”, but metal is to expensive right now.
Must not be a 40 owner who suggested this… or at least not a pre-79 one.![]()
haha, also must not be a 40 owner talking about driving fast loljust drive fast and don't be in the back the first time you take off.
Have a stock 2Fin my 77 and it will roll just fine.haha, also must not be a 40 owner talking about driving fast lol![]()
Pushing up on a trail cover or bikini or...?I went the high tech route to prevent water from pooling on my soft top.
I cut a section of 3/4" pvc pipe to length so that it pitched the centwr of the top like a tent.I wedge the pipe between the top and the tub floor.For added protection I taped a rag to the end of the pipe that sits against the top.The pipe lays behind the rear jump seat when not in use.
I have an FST .I use the pipe to push up on the center of my soft top.I also use it when i have a bimini top on.It will work for any soft top,bikini,trail cover,etc.You just need to create a slope to allow water to run off instead of pooling.Keep it simple.
