Pardon me, is my Engineer showing?
Stump, maybe I should have described it in terms you can relate to...how about, Ryan's handy work could no longer constrain the tubular member after it swelled in the heat of the moment and spewed forth the liquid from within?
What tool does one use to un-stake a stake nut on a pinion? I'm changing out the flanges on a set of 3.70 3rds I got from Gary. Also, when I pull the flange off do I have to rest preload? Replace the crush sleeve? My plan is to swap the flange to the correct pattern for my 77 (3rds came off an 86 FJ60) and replace the seals since I'm in there. Any issues with this logic?
Just that you will have a hell of a time setting pinion preload on a 3rd that is not installed in an axle or otherwise secured.
Went ahead and bought a new rear locker actuator and installed it. I didn't realize these were available from Aisin until a couple days ago. Bought it from Rock auto, here in 2 days.
I also swapped out my driver's window regulator to see if that would speed up/down but much to my chagrin it had no positive effect. I guess I'll change out the window runs next.
