Pretty quiet in here... what are you working on?
I replaced one years ago with a repair kit it worked for about a year and gave up again. My current one was leaking and Ryan said just replace the entire cylinder because all the repair kit does is buy you a bit of time. I can see it being an option for a trail fix but agree replacing the entire thing is easy and better.
Getting close
I changed the oil on the 40 and 45 and noticed the water pump on the 45 was seeping. I searched all over for an Aisin water pump but ended up with a GMB. I filled the radiator back up after replacing the water pump and noticed that the radiator was also leaking - great! The radiator is NLA from Toyota so I ordered a radiator from Amazon. I get a notice two weeks later that my order is cancelled because they no longer stock the item, thanks Jeff Bezos. I tried to have the original radiator and a spare repaired but both were beyond salvage. The radiator I ordered from CCOT arrived yesterday and the 45 if finally back together. I'm ready to move on to a non-Cruiser project for a while.
Got my new slave and master cylinders. Apparently what I thought was a 40 clutch soft line was a 80 series axle to frame brake line. What's different you ask.... About a 1/4 inch of threads. I'm fairly certain I have the right line, I just need to find it.
The parts joker at Ourisman Toyota just tried to sell me the hose for $100, when I told him the hose MSRP'd for $78 and I could find it online for $56 he told me he could do it for MSRP. Talk about stealership. I promptly hung up on the guy.
Ordered from @Racer65 for $52 shipped. Guess I won't be back on the road for a few days.
Got my new slave and master cylinders. Apparently what I thought was a 40 clutch soft line was a 80 series axle to frame brake line. What's different you ask.... About a 1/4 inch of threads. I'm fairly certain I have the right line, I just need to find it. View attachment 1997010
if the female end depth matches the original and the hose length is close. That hose will work fine.
Installed the hand crank bracket I picked up from @Weber Sarge . Not sure how useful this is but I thought it was pretty cool none the less.
From the angle I can't be sure but it looks to me like the end on the right is a flare fitting while the one on the left is not a flare and seals with the copper gasket. Is that correct?
