Possible bad birf?
I purchased a 94 fj80 a few weeks back. Stock suspension, 30 inch tires. Nothing crazy. 168k miles
Yesterday I noticed a slight creek/ pop noise when turning into a parking spot. I figured I needed to replace some bushings sometime soon or the birfs were on their way out.
Just got done 4 wheeling today and now I have a slew of issues I'm hoping to be from 1 part.
When I disengage 4 low, the diff light takes longer to turn off I believe. I never timed it before but it feels like a long time. The vehicle will be in 4h, but the light stays on.
When turning in 4 low the popping/grind noise is very loud.
When I accelerate from a stop or slow roll in 4h, I hear a grinding noise. My buddy swears it's coming from the wheel, but I feel it in the steering wheel and hear it in the center of my front axle. Slow acceleration and shifting seem to be fine. Coasting into a turn, changing lanes, getting on an off ramp I didn't hear anything.
When I turn hard, I hear it click and pop in the front wheels.
When I disengage 4l, and go to 4h, I sometimes hear a "ping" almost like flicking the spoke of a bicycle, but louder and stronger.
Doing research I think it's the birfs going bad, but would they contribute to the acceleration noise?
The drive train looks fine, I don't think I've broken anything there.
Im really praying it's not my transmission and suspension.
I guess the questions I have are
1) are these symptoms pointing to dual birf replace?
2) can bad birfs pop or grind when going straight under heavy acceleration?
Search clicking birfs.
I've read many of those. Most of it applies to them clicking, popping or grinding whole accelerating through a turn.
Would there be any grinding with the birfs when accelerating straight line?
Not much, no.
I would think that more stress is put on the front birfs and bearings with the steering fully turned and especially with the CDL locked (4low), therefore the noise.
You can pull the front wheels off and add grease to the steering knuckles via the square plug. From there it's not too much more work to pull the front hubs and check the wheel bearings. The FAQ has an excellent write-up detailing these procedures as well as the full knuckle service.
If the truck has no known service history you should be doing this stuff anyway, and plan for an knuckle rebuild soon. Lots of folks have many more miles on their original Birfields, myself included (256k), so I wouldn't be stressing new birfs quite yet. Good luck!
Okay, thanks. Iooks like I'll be disassembling my truck today.
So should I check these things in this order?
Steering knuckles
Hubs
Birfs
Transmission
Nothing in your write up suggests transmission to me.
I would stick to wheel bearings and birfs. The wheel bearings will be pretty obvious if they are shot, the birfs not so much unless you have a lot of experience with them.
You said you recently purchased the vehicle. Have you checked that there is lube in the steering knuckle? When I got my rig it was low, started clicking. Filled both sides up about 2/3 full...stopped the clicking. It takes a few days of driving around for the moly lube to work its way into the birf joint (if dry). It might be worth a look.
It could also be drive plates on the end of the hub.
Don't have to remove the wheel and hub for a basic wheel bearing inspection. Jack it up, do the 12:00/6:00 thing tipping it in/out to see if it is loose.
Do the square plug fill with grease. Take off wheels? eh? Just lay down in front of the tire with a crescent wrench, toothbrush and compressed air if you have it. Brush the crusted crud loose, blow it off, remove the square plug with the wrench. Stuff the grease gun in. A hand gun takes about 500 squirts to push in a half tube. Do that on each side. Drive it around, backing and going forward at full lock a few times slowly. Then take it on a 10 min freeway run. See if it makes a difference. I did an experiment and the fresh grease gets distributed very fast - a few miles. I think yours are so dry the bronze spindle bushings are dry and that's the straight ahead noise.
Anybody got a picture of this square plug showing reference location and is it accessible without pulling your wheel/tire???
Thanks!
Not my photo but you can get the point.
Thanks again...nice and clean front knuckle section!!!
Like I said not my photo, it belongs to someone else on the forum, it is an early 80, maybe the early ones had the vented dust covers. I just wanted to find a pic of a clean knuckle so I could highlight the inspection port.
