Wait until you get new Birfield (CV) joints so you don't have to mess with it twice. The ones you have are pretty worn. You can tell that it is the CVs making the noise because they click 6 times per revolution of the wheel. That is because there are 6 balls in the CV.
So I'm going to call around tomorrow when I've got some time at work.
Here is what I'm thinking.
I know the drivers side axle has inner/outer axle seal leak. So a rebuild kit there for that knuckle.
While the passenger axle it's apart to confirm that the birf is bad, rebuild that knuckle as well.
I'm going to bank on that birf on the passenger side being bad so replace that one, and while I'm at it, replace the drivers side birf as well while it's apart.
Why not just do the front axle service procedure outlined in the FSM since you don't know if/when it was done last? You will find a possible smoking gun while your at it and if not then your all lubed and sealed up for a good while. Not difficult or expensive but it is messy and satisfying!
So I power washed the front end. Found another problem. Hopefully not big.
The passenger side knuckle has 4 male end screws facing down.
The drivers side only has 3 screws going into the knuckle housing. I know it needs a 4th and the screws are most likely bent, but hopefully the threads inside are okay.
Are screws going into the knuckle normal?
To answer your question about the front axle service, Im kind of crunched for time on getting the work done, as well as having the parts on hand to fix what's needed.
Somebody removed them and put in bolts. You can remove and install the studs from the outside. The stud/cone washer, split washer and nut are dealer items.
Oh okay. So what your saying is I can call cruiser dan and email him a pic of this and I'll be able to order the parts in order to rectify the situation?
It looks like in one of your pictures that the threads in the knuckle casting hole missing bolt are stripped out. If so you wil need a helicoil or timesert thread repair kit.
Yeah, I noticed that too. Not exited about it. If I ever get this front end sorted out, I plan on putting larger tires and a 2 inch lift or coil spacers. This is going to be my hunting/fun in the mud/daily driver. So with that said, do you think a helicoil or thread kit will hold up to that? It seems like a pretty integral part.
Yes. I had a helicoil in the knuckle of my FJ40 for more than 10 years and I wheeled it harder than my 80. It is easier to do when the knuckle is removed.
Yeah, I jacked the drivers side up, and I could shift the tire like 2 inches either way there was that much play in it. As soon as I tightened the remaining 3 down, the gear fluid just poured out of the casing. So it will be coming off here hopefully at the end of the week and I'll take a shot at getting the heliciil to fix it. Do you think it would be worth while to remove one of the remaining 3 to see if that's actually the case?
They tightened the control arm back into the knuckle housing. But if they are reversed for some reason because they are all stripped out, should I consider replacing the housing? They index the bearings right?
I would do what @scottryana and @Pin_Head say, and get a new knuckle with studs. My PO had sheared off one, two more fell out, and the last one was working its way out. Don't drive it with any of them loose. I'm guessing that your PO did not do what he should have done on the front end. This may indicate more of what your overall maintenance level has really been. Take a close look at everything and assume nothing was done correctly.
Get a used knuckle from one of the vendors or on the classified section above.
