Possible bad birf?
Contact @arcteryx for used parts. Stand up guy.
After driving to work and sitting for a few hours......
Anyway, I ordered 2 terrain tamer birfs, a terrain tamer knuckle overhaul kit, and a used driver side knuckle with steering arm from arcteryx. So essentially a full front axle rebuild minus the axle and diff. That knuckle was way cheaper than I expected.
I'll keep you guys posted. Thanks again.
Alright, both knuckles rebuilt and birfield joints replaced. No more grinding noise or leak. My garage lookd like a transformer axe murder scene....
Here are the issues I ran into while fixing it.
First off, thank god I ordered a new drivers side knuckle. The stud housing holding the control arm on the bottom was stripped to all hell and it was mangled on the inside. Metal shavings everywhere. The wheel bearing actually disintegrated as I took it out.
The first issue, on the long side of the axle, I couldn't separate the axle from the birf. Reason being, the c-clip had expanded inside the birf. No matter how hard I smashed the fence post into the ground, I couldn't defeat it. I actually ended up cracking the birf. Which led to me actually getting a chisel and breaking it apart, peeling the c clip out, and being able to get the new birf on. Caveman style. Took me 6 hours to defeat that joint. No damage to the axle, they both looked very good considering the age.
Replacing the tie rod ends was kind of a chore. I bought a mapp gas torch, heated the old end up, dunked it in ice, sprayed it with penetrating oil and repeated the process. I actually bought a small chisel, and very carefully hammered it along almost perpendicular to the tie rod where you can see the threads of the tie rod end going into the tie rod to create space and break the threads away. I was careful not to mar the threads that were still inside the tie rod itself allowing oil to penetrate deeper. Sombich was stuck in there. The same birf separation pipe came in handy as a pipe wrench extension for added torque.
I also had to wait a few days as the tie rod ends were special order from every store around. Order those in advance because I broke the ball joint away from the rod end trying to knock it out of the control arm. The rubber boots were mangled, so if you plan on taking them off, plan on not reusing them unless you are a surgeon with a mallet and whatever you use to separate them. None of the tools any of the auto parts stores seemed to fit or even help. Again, Caveman style.
The straight forward grinding noise I mentioned earlier in the thread was actually where my muffler/cat converter broke from the mount, bounced over towards the drive shaft, and was getting hit by the cv looking joint right where it lines up with the cat converter. It was more prominent under acceleration due to the compression of the rear coils and frame movement. A u-bolt to the frame holding the exhaust out of the way fixed it. Still rattles over bumpy roads, but I know what it is now
Draining the front diff fluid, it looked like watery mud. Even after putting some new gear oil in there, I accidentally over filed it. Thank good I did because what came out of the fill plug was nasty. Water must've came in the knuckle, and migrated into the diff pumpkin, mixed around and made a nasty soup. When I pulled the drain plug, there was actually molly grease on the plug.
My next quest is to figure out what this whine nose is at around 45 mph. It doesn't happen in neutral or not moving. If I go 60mph and drop it in neutral, the whine goes away even if I rev the engine. It only happens when I press the gas pedal. Makes me rule out any fan or belt. Only under load does it make the noise.
It comes from the engine compartment, from what hopefully sounds like in front of the transmission. My wife says it sounds like an 18 wheeler, but those of you in the service, it reminds me of a humvee
I think the battery is going dead because after working on it, I had to jump the truck to start it. So maybe an overloaded alternator? Throwing my meter on there, the battery reads 12.6v but my lights dim or brighten when changing from brights to normal, or initially when rolling up my Windows.
So I'm thinking, either a bad fuel pump, transmission pump, water pump, a leak in the exhaust, air intake, or the alternator is being stressed from a dying battery. It sounds like a power steering pump, that gets louder as speed increases, but can really only be heard starting at 45 mph getting higher pitched as speed increases.
New gear fluid front/back diff, new tranny fluid, too far forward to be trans case fluid.
With an fj80, 168k miles, is that a normal-ish sound? Looking around online people mention a butterfly valve or maybe bad fuel injectors? Some also say it's normal worn in gear noise. My axels didn't seem chewed up on the diff side.
The only fluid I haven't changed yet is the trans case. Everything else is new.
