Poly gas tank??
TN
Have any of you guys replaced your stock gas tank with a poly tank? How well does it fit with respect to the stock tank? Are their any advantages to this or would a factory steel tank be the best bet for a resto.? I was looking at the one from CCOT, any other suggestions.
Pros; Cost
Cons; They are smaller, hold less gas, filler neck on tank is smaller diameter than the stock hose, gas gauge sending unit doesn't seal well.
My opinion is they are junk! I'll be replacing the one I have over the winter with a steel tank. Wasted my money by buying the poly tank.
Lane
Lots of info and previous discussions out there...try searching.
General consensus is that they are hard to seal and make the inside of your 40 smell like gas. For a truck that is always open...so what. The smell can be lessened usually by paying extra attention to the area around the sender.
There are people on this forum who have offered one for free in the past as they just wanted to get ride of theirs.
I see CCoT has a new repro steel tank out now. But at only $40 less than an OE Toy tank from CDan, why not just go OE?
Sealed sender, replaced filler neck, Piece of crap still smells like gas. 12.5 gallons will get you about an hrs worth of riding around here. It sucks. I wouldn't even give you mine. I would never wish that piece of crap on anyone. Save up. Steel is the only way to go.
I have one in my truck.
Bought it when I was younger and more foolish.
It gets the job done, got a hose adapter from Napa for the filler neck, sealed the sender with RTV.
I don't run a top anymore, so there isn't any gas smell from it.
It is a plus that it will not deteriorate, my floor is constantly full of water/mud/silt.
I would only consider one for a trail truck.
They warp. They leak. They stink.
CCOT claims to have solved problems - will YOU be the one to try it out?
I also run the poly tank, I have no top so I do not smell fuel. I have ran it on trails and have had no problems leaking, I did seal the sending unit. If I had to do it all over again I would spend the extra $ and buy a OEM tank. I was lucky and only paid $40 for my poly....The OEMs will rust, but it will take 30 years....
I bought my poly before I joined the forum, but I kept the original. So, I plan to recondition the original tank so it will be ready in case I need it.
I have the poly, I wish I didn't.
I replaced the stock tank because I thought it was rusty. Now I don't think that was the case, but I don't have it to put back in anymore.
I hate the gas fumes, I don't like having to fill up every 2 days, and it's not baffled. When I make a hard left turn it sloshes out the cap (as in, gas down the side of my rig), and the engine starves for fuel. The same thing happens when sidehilling.
I think a single baffle in the center would make me not mind so much about the smaller size and would stop the fume inducing warping. The only good things I have to say are that it won't ever rust again, and seems to be a high-enough quality poly not to crack in extreme cold.
I agree, I had a leaky original and bought the poly and it ended up being more of a pain in the a$$ than anything and the seals on it suck. When i put the top on in the winter it smells pretty strong.
if it's leaking, there really is no good way to fix it, easily.
