OM606 diesel conversion FJ62 CAtuned off-road
Is that like a 5psi pump typically used with carburerated engines? I've been considering something like that, or just leaving the intank pump on mine and using a regulator to drop the pressure down a bunch
Here's the information on the pump
Holley 12-428 Details
30-39 GPH Flow Rate
Should be mounted below the fuel level of the tank for a good gravity feed on the inlet side.
Features:
  • 12-volt operation
  • 7-10 psi operating pressure
  • 34 gallons per hour flow
  • Good for up to 400HP naturally aspirated
  • Reliable solid state design provides longer life
  • Compatible with all fuels and fuel additives (gas, diesel, blended alcohol, ethanol, e-85)
  • Simple 2-wire hookup
  • Self-priming and regulating
  • 50'' dry lift capable
  • Quiet operation - 65db
  • Great for carbureted trucks, cars, generators and agricultural equipment - also makes a great transfer pump
Here's what the engine bay looks so far. still need to make intake box battery box couple wires to hook up, AC lines and exhaust
This is pretty cool. I'd sure love to have a diesel in my 62.
That's beautiful.
What air filter setup are you going to use?
Are those universal fans or off a specific vehicle? Can we have more more pictures of the intercooler/radiator mounts please? Beautiful install looking forwards to how it performs.
SPAL 30102052 Electric Fan, 11 Inch, Pull Style - Paddle Blades
Features
  • Style: Pull
  • Diameter: 11 Inch
  • Air Flow: 2720 cfm
  • Type of Blades: Paddle
  • Profile Type: Dual High Performance
  • Actual Weight: 10.75 lbs.
  • Height: 4.25
  • Width: 23.46
  • Length: 16.26
Mad skills max! Very tight setup. I love the intake and intercooler/rad. How many HP's does that engine come with?
Thanks
Stock Engine with no modifications
OM 606.962 ERE 130 kW (177 PS; 174 hp) @4400 rpm 330 N·m (243 lb·ft) @1600 rpm
With my engine modified injection pump and more boost estimating 350hp
WOW! YEEE HAAAAAAA!
looks good, I know a lot of work has been put in to get it this far.
Thanks
Now that's a nice diesel cruiser setup.
So its just a IP tuned engine. No modification on the injectors? Advanced/retarded timing?
