Were you ever able to shift without using the clutch? I'm able to shift through gears on mine without as long as I'm in the rpm range of a normal shift. May narrow down the issue but I'm just guessing.
The push rod can look like it has full travel, but it's the throw out bearing that matters which is inside and not visible. The nut on the push rod needs to be adjusted, possibly out further than it is, to where the throw out bearing is close but not touching the release levers on the pressure plate. I would take the spring off the release fork and move it by hand to get a feel for when the throw out bearing is touching the release levers. That will verify where it should be at rest. Then adjust nut on push rod until it's held at that position. Add spring back. That will give you the max travel on the pressure plate. Remember the clutch slave is short travel so it need to be adjusted to make best use of the limited range.
