Noob falling HARD
Finger Lakes, NY
OK, I've been lerking for a while.
This summer I bought a stock 79 and then a 73 that was mostly stock. After numberous upgrades, it's time to ditch the F engine in the 73. The F engine just won't turn the 35's.
So...I've purchased a 6.0L out of an Escalade.
Who has the best conversion parts?
AA for conversion parts or classifieds here on Mud.
You could bolt in a 2F for a ton less $$$. With 4.11 gears it should turn 35s fine. With the $$$ you save you could get an Orion.
Or, you could swap in an sm465 for a lower crawl ratio.
That said, it's your rig. Build it the way you want to. I'm running a 350, and have no regrets.:cheers:
Send the harness and computer to Jims peformance and tell him what you are doing with it and he will flash your ECM to a nice program. Make sure ever who does your harness and computer knows what they are doing or you will have a headache. My fourwheeling club uses him a lot and I highly recomend him. As far as the adapters if you can get the factory tranny out of the vehicle use it and just adapt the tcase will be a lot easier on gas in the long run as well as probably hold up a little longer but that depends on your driving.
Thanks Guys,
Went with AA and a H55F...the wrost part is the body right now. More rust hidden than I imagined.
Otherwise so far so good.
I have the batwing cross member but I'm nervous about using it.
OK OK. Stand by for pics. Jees!
Here's what it looked like when I bought it last spring:
Here's what it looked like after driving it all summer and making some mods:
Here it is building the roll cage:
Here it is in process:
Here's the LQ9 and the H55F:
Man, judging by your shop, tools, mods, etc., you are no noob. Thats a great looking rig and a killer drive train you're throwing in there.
I'm jealous.
Good luck with it and keep the updates coming!
-Ed
Thanks Ed.
I'm a Noob when it comes to the ins and outs of FJ40's.
Resurrection
Its been 10+ years and there has been many trials and tribulations on this job and in life. But perseverance pays off. This machine is almost finished and I have been under pressure to update Mud...
