I'll add that the PNP switch (neutral lock off), acts much the same as bad starter contact. We turn the IG key to start and nothing happens. In that we do not see voltage drop or dash lights dim. We'll not hear any click at starter. Nor will tap, tap tap result in starting. But shaking/vibrating vehicle or shifter movement may result in starting.
The one that had me needless replace a newish reman starter. Was a short, in aftermarket dual battery set-up, due to loose lug. Kicking myself on that
. But it was in a VVTi. So I doing the S.A.I filter MOD while in there, it wasn't a total waster of time.
Caution: Always clean top of engine before removing intake manifold. Pay special attention to valley between intake manifold and heads and around fuel injectors. As we don't want sand dropping into intake ports of heads.
