- Joined
- Jan 12, 2008
- Threads
- 300
- Messages
- 3,609
- Location
- West MI near GVSU
- Website
- www.mcdesignsoffroad.com
So as the title states, I have to do a test on a 4.6 rebuild with 6K on it. It has a terrible miss and seemed to be running on about half of the cylinders the last time I limped it home. I did a search about numbers I should hope to see, but would love any additional wisdom.
I can't really rev the engine as described below as it won't stay running unless I rev it like crazy. Should I rev it for a bit to warm it?
Reviving "the wife's" 80 Last post
[/QUOTE]
-warm engine, allows metals to expand, shows you normal operating conditions
-hold throttle wide open while cranking
-crank same length of time for each cylinder
-you are looking for results to be within 10% of each other
-if you have a cylinder that is low, you can put a cap of oil down the plug hole and retest, if the numbers come up to match the other cylinders then you know you have worn piston rings, if the numbers dont' change signifigantly then you have a head gasket or head issue that is the cause of the low compression
-don't worry so much about what the actual #'s are, just that they are close to the same. Different testers, altitude, length of time you cranked over, lots of factors can influence the results so you can't compare them directly to someone else's results with any accuracy.
[/QUOTE]
Look great to me. Important thing is the numbers are all close to each other, not necessarily to those from another truck.
From another thread:
[/QUOTE]
[/QUOTE]
