- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
Ok, for some background-the head was checked and rebuilt about 2000 miles before the bottom end.
The valves were checked by the same shop that did the lower end.
I just bought a compression tester and had these terrible numbers:
1-150lb
2-170lb
3-60ish lb
4-30lb
5-15-20lb
6-30lb
At 4 I tried the oil on the piston trick to see if it would hold more pressure. It didn't.
Am I looking at a bad HG?
That type of result is almost always valve(s). To confirm; remove the plugs, bring the target cylinder to TDC/compression, pressurize with compressed air and listen where it comes out, intake, exhaust, other spark plug hole, oil cap or radiator bubbling, this will tell the story.
The "proper" tool for this is a leak down tester. I have one, somewhere, never use it, over complicated for the job, and the results are even more subjective than compression testing. The quick, dirty,
, but effective way: Most compression testers have a hose that connects to the gauge with an air fitting, the spark plug fitting end has a schrader valve (like a tire) in it. Remove the valve, confirm the hose is free flowing, screw it into the spark plug hole, connect the air supply,
and effective.
