Native SJ/CA 87 FJ60 Build
Side Before
Side After
Sick of being in the engine bay or under the truck so I’ve decided to spend a few days on the exterior. I removed the glue from a PO bad tint job.
The undercoating has worn off quite a bit over the years so today I tended to the wheel wells.
PRODUCT
BEFORE
AFTER
This weekend I plan to try out this 3M windshield chip repair and touch up using Dr ColorChip (which I’ve used before on other vehicles).
I’ve spent some time on minor details, and fun stuff - so here are some updates!
Used the 3M windshield chip repair kit with mixed results. The instructions don’t say to shake the resin bottle before applying so it didn’t want to dry in its first application. Once I figured out you have to shake it up well, much better.
As you will see below, it did fill but with some bubbles and definitely not a professional job. Overall I like the kit and feel I could do much better given another shot at it. Hopefully it prevents further cracking.
On another subject - without oil in the vehicle, it’s clear there is another source for an oil type leak. It looks like it’s coming from where the front drive shaft connects to the transfer case. Any thoughts there?
Smell like gear oil? may need to take off the drive shaft and replace the seal. Also put some rtv or fipg on the splines to keep gear oil from slipping by.
Thank you. It sounds like something I might need to be doing soon. I haven’t put many miles on it since getting everything cleaned up. Hoping to drive it a bit more to see what’s really what under there.
Any advice on a new drive shaft? I see some guys install new. Unnecessary?
Somewhere along the line the truck inherited some door and wheel well bumpers. It’s actually growing on me. One wheel well and all of the doors need replacing. So I tended to that a little today. It’s raining, and I’m allergic...
I also haven’t looked under the vintage front seat covers since i bought the rig - pretty good shape! I’ve been debating some sheepskin covers. They’re just so expensive.
