Build My New Project
Third time is a charm!
We took a drive yesterday morning. The knock sensor triggered the check engine light (P0327). This was the second set of sensors in one months. Frustrated!
Dug into it again. I'm getting good at removing the Intake manifold.🤪. It's just another 2.5 hours in the garage.
Everyone says; be sure to get the AC-Delco sensors. Pay extra and they are faulty. 3 of 4 bench tested faulty with an ohm meter. Arghhh!
This time I decided to take a chance on the Autozone brand with lifetime warranty. I put 175 miles on today after they were installed and no warning light. It's about friggin time! Hopefully I didn't jinx things with that.
Any warranty? Are you sure you got genuine GM parts? eBay has lots of counterfeit stuff...
Actually just got home from a drive with my wife. Drove for some top notch Oklahoma BBQ and then put in another 100 miles on along the local highways. All is good. No knock sensor light and just a good shake down cruise. The dog even enjoyed the ride stretched out on the back seat.
I'm trying now to decide if it's roadworthy for a trip west on I-40. I'm selling the house and going to retire in Durango. It's about 750 miles and it's a debate on driving it or trailering it. I really didn't like trailering my FJ40 out there. I've only put 800 miles on since getting it tagged. Just a little nervous about a big road trip.
Now I am hungry! Those look oh-so delicious...
All ordered via Amazon so last set credited okay. First set was a victim of Thanksgiving and more than 30 days passed so the return date expired.
They were all labeled genuine AC Delco packaging. All good, just frustrating to have to do it three times. 🤓
It's @scrapdaddy 's fault. I had been researching master cylinder changes from my 1 1/8 bore and unsure what improvement I would get with a 1 inch bore. My braking really sucks even with the 60 axle components. A 7/8 bore is hard to find that will bolt to my booster. Then scrapdaddy opened a door for hydroboost. I hadn't explored it but it seems like a great option since I have GM components at the power steering pump. I'm in! I picked up a $60 booster at the Pull-a-Part from a '04 Tahoe. Only vehicle in the yard with a hydraulic boost.
Rebuild kit seems likely and should bolt to my existing master. Then its about hoses and an oil cooler. I'm wondering if a secondary reservoir could replace a cooler. More volume so it would circulate less and stay cooler. Thoughts?
Do you have a way to plumb in a second reservoir, seems like it would be easier to use a small cooler. An auto. transmission cooler works great and easy to mount somewhere.
That hydroboost unit new is @ $500.
Gotta question.
What gas caps are people using? Everytime I fill up I have gasoline running down the side of my pig by the time I get back home.
I’m curious if it’s the cap or it it’s being caused by the return gas line I installed for my 5.3L.
It’s a new cap from CruiserCorp.
I did a fix years back that involved grafting the upper threaded section of a later model truck’s fill tube to the lower LC section of fill tube to make use of newer, more common, o-ring sealed gas caps. They vent air in but not out, so the venting of your fuel tank has to be worked out. Does a great job of keeping the fuel in the tank.
The other option is to get a factory style cap and gasket from Cruiser Outfitters.
Tell me more about what’s special about the Cuiser Outfitter cap and gasket. I assumed my cap from CruiserCorps was factory style.
Nik,
Anything different with your fuel vents, tank , etc from when it was stock. This just start since the motor swap? Trying to think what would cause it. Maybe it's getting over filled and the vent line can't handle the pressure until the level goes down a tad, just spit balling.
I have done the same as rush in 2000 ,grafting in a newer neck . no leaks at all
I have no knowledge of how a normal 55 functions since I didn’t have a running version and immediately went to work swapping in my 5.3.
It’s a stock tank and the only thing I did when I had the tank cleaned was to weld an AN fitting on the bottom to connect to my fuel pump and another AN fitting on the top side for the return line. (And plug the standard carb line)
I assume the venting is through the cap because this model has no vapor recovery plumbing and all the associated stuff.
Today I drove from Oklahoma to Colorado and each time pumped until the auto shut off triggered. Each stop I immediately got on the freeway. I didn’t notice any gas dribble down the side so I’m thinking it’s associated with sloshing when cornering etc. (which didn’t really happen today).
Last night before I left I wiped the cap gasket down while I was inspecting it and also wiped down the mating surface on the 55. (It can’t be that easy). I’ll have to see what happens next time around town.
