What are you guys ordering, MiniH1 or D2S 4.0?
You won't need shrouds since you reuse the factory shrouds. Get the updated bulb holders that eliminate the shimming sometimes needed to properly align the bulbs in the projector. I attached my order. Use "TRSHJ" code for 10% off.Odered the H1. Any chance you can publish a complete list of what's needed from TRS to install?
Thanks. Mostly wanted to be sure which harness to use.You won't need shrouds since you reuse the factory shrouds. Get the updated bulb holders that eliminate the shimming sometimes needed to properly align the bulbs in the projector. I attached my order. Use "TRSHJ" code for 10% off.
https://www.theretrofitsource.com/complete-retrofit-kits/universal-kits/bixenon-morimoto-mini-h1-stage-3.html?preselect=50325,52286,51812,50560,47308
Luke do they need to be painted or are they good to go?
Love what you've done here. Can't thank you enough for taking the time to explain everything and to make an awesome product available to all of us at an affordable price.
I'm in need of some new headlights (the entire housing because my front plastic covers are cracking) and figured this would be an opportune time to ask whether I can order the D2S 4.0 pre-built from you in the headlight housings?
I'd also like to install the bi-xenon's in the high-beam slot like you mentioned and have quad low-beams and quad high-beams. Is there any way I can order those from you pre-built as well?
It's something I'm considering, keep in mind I'm pretty much a newbie at the retrofit process.. there are companies out there like Lightwertz
who can do this in there sleep. I have a call into them about the cost to retrofit a few brand new light housing
