Build Live in Texas, drive a pickup: HDJ79 single cab build
I know. We’ll paint stuff soon.
At the end of the day, I was dying to see if anything would actually power up and switch on. So I grabbed a battery, some terminals, and clicked the ignition over. Awesomely, the sub tank dash light comes on when switched and the odometer powers up.
I really wanted to see if I had plumbed the solenoids correctly, so I checked the sub tank switch.
And then I realized that duh, the transmission harness was connected, but there was no engine harness in between it!
My theory is that with no power to the solenoids, the default setting will be fuel flow from the main tank to the lines. When you energize the solenoids by pushing the sub tank switch, you give 12 V to the solenoids which will route fuel from sub tank to motor and back. But I’m going to have to wait just a little bit because I sent my engine harness to Australia to have the FTE harness built.
Kelly, there may be MORE THAN ONE.
I have always heard rumors they were in that garage someplace but never believed it until I saw a small corner of one. Glad the rumors are true. ;)
@Meshal - no flashing, but also no solenoids attached! @rick_d just sent me that flasher information this morning, too!
My harness is 2001 HZJ79 and the body is 3/2009, so there are some known differences - A/C thermistor and blower motor - but most stuff seems to match.
I am starting to work on populating the harness with relays and am having a hard time figuring out where the starter relay goes. I have the glow relay on the driver's side fender well just before the fusible link... but not starter relay plug anywhere that I can see. It is a bit of a mystery. Does anyone know if it fits on the engine harness 82121-6A131? My harness is in Australia.
This look correct but is it?
If you have a buddy in Dubai the buddy could go have a look at the HZJ79 project I'm working on. Near as I can tell it has not been modified. Neglected, but not modified.
The harness in the engine bay has not yet been touched I believe. I am not in Dubai at present.
@Meshal I have the dash instrument and AC harnesses. I see a couple of extra wires on the parts diagrams…. I hope I don’t need any more wires.
While we are at it, do we know where the diff lock switch is on the driver’s side?
Is it a 16 pin sub harness like the 80 series or is there a different harness just for the diff lock switch?
I need to look up the pin out diagram for the 79 versus 80 locker actuators. They are both six pin connectors, but different shapes. The 79 diff wire has a separate 2 pin connector, too.
I got a spare harness I’ll take pictures of the locker connectors you need.
I looked again today. There’s just no damn spot on the harness here.
I am thinking that it HAS to be on that engine harness.
Should be on the other side, I believe this is mine for the front diff (bottom one)
Oh man. It’s HERE.
A completely plug and play engine harness to run the FTE. Built by Mick Wallin in Australia. I sent him a 1HZ engine harness and he modified it extensively, then added his standalone FTE harness.
Love it, nothing more satisfying than having a sano wiring harness. Saves so much time and heartache, plus adds a huge factor of safety to the vehicle. Looking forward to seeing this installed.
OK. I got the wiring harness laid out in the truck today. It’s hard to get good pictures, but I’ll see if I can describe it:
The modified engine loom plugs into the main cowl harness at the left fender just in front of the firewall. This is a direct pass-through to the transmission harness. Mick’s FTE engine loom plugs into this harness, runs the engine sensors, and then passes from left to right along the firewall. I drilled a 60 mm/2 3/8 inch hole in the firewall below the existing cowl harness firewall grommet. I then placed the ECU inside the glove box at the far right. I passed the pedal loom on top of the A/C all the way to the pedal box. And that’s all I had time for today.
