- Thread starter
- #221
mines a husky, and its still holding up just fine.
I did the same today, I cant seem to find a glass bowl oil separator. That would last a while
Any photos of this installed? What are the dimensions of it?This is the one I bought but haven't had the time to install yet.
$17 delivered, site window/tube, metal, drain valve, install hose included and a easy mount. You can also order in different colors from same seller.
http://item.mobileweb.ebay.com/viewitem?itemId=190626546819
Side shot shown but you get the idea. Brass inlet and outlet go to the top. Lol.
Great to know. I had seen other posts from folks indicating that they got about two years or so, which I'll be pleased if I get as well. Thanks for starting this thread as well. It came in real handy. I'm probably going to have to modify the plug that I put in to replace the little valve with a slightly different rubber washer or grommet to make sure it's tight.
Tag for additional info.
[/URL]Will this work ??
[URL="http://i184.photobucket.com/albums/x39/Sapcut/IMAG1292_zps30d63dd4.jpg"][/URL]
No, once the oil saturates the filter and fills the housing up to the hoses, it will be sucking down raw oil into the intake![]()
I guess by then I could change it out..??
