Holley Sniper 2GC to 2F Install using Mosley Motors adapter
So does this look correct?
I’ll keep extra fuel filter on hand as spare.
Old Fuel lines removed. Both rubber lines from tank to hard lines are 5/16 and had hardened making removal difficult.
kit comes with 3/8. I’ve got one coupler from 5/16 to 3/8. Will have to get another for return line to tank.
You could just come straight out of the filter/regulator with a 5/16” barb.
Yeah I thought about that. Need to get a 5/16 hose barb to -6 female.
Wouldn’t have figured out the Corvette Filter without reading @wngrog build thread. See post # 28
This is how I interpret
After watching ‘Project Wrong Way’ was left wondering where is the best place to mount fuel pump?
Anybody have suggestions or pictures?
I have watched Ben and Rachel’s videos for over 2 years now…. Surely beats the crap that is on TV and they are informative and entertaining. Just starting my Sniper install this week as well.and of course and re-watched several YouTube videos on FJ40 sniper installs. There are probably over a dozen or so. Ben and I work the same way so it’s perfect. Never afraid to dig in and try it. My stopping point has to be the trans, transfer case and differentials…they’re way too heavy these days for me
The last few weeks my project derailed when I went chasing debris in my fuel tank.
I removed fuel tank sender and borrowed a scope to see what lies beneath. The images looked like the landscape on another planet. Big black flaky sh#t, some light surface rust etc. I’ve been watching YouTube videos on cleaning a rusty tank (and pricing new Spectra tank).
I decided to try good old fashioned vinegar. 8 gallons of it to be exact! This is the 5% stuff available at Sam’s. With tank still in truck, I filled her up and I let it sit for a week and then siphoned it out. Put the scope back in and looks like it loosened a lot of the debris but not to my liking.
Last night I removed the tank from underside of tub (1981 FJ40). This was a huge PIA! I planning on trying to clean the tank more thoroughly with tank out of vehicle.
While trying to remove tank I noticed a little seepage at fuel tank plug. I’ve read here on Mud that plug gasket is NLA for ‘79+ FJ40s. Surely there is a suitable replacement out there ???
Should I remove plug and seal some other way or leave it friggen alone?
What have others used to seal fuel tank plug?
Does anyone have part numbers or links to order replacements of the fuel pump and fuel regulator/filter?
watch to make sure the fittings are correct but these will get you pointed in the right direction.
Thanks!
I have had the Sniper installed on my 40 for a few years so should be able to reuse fittings if necessary.
I suddenly developed a misfire, eliminated O2 sensor, spark plugs, and timing, so moving to fuel delivery and IAC motor.
Neither fuel deliver or IAC are likely to cause a misfire. Those are going to contribute to "all or nothing" type problems.
Are you sure it is a actual misfire or is it just running poorly overall? If it is an actual misfire you should be able to narrow it down to the specific cylinder.
Initially there was one day it didn’t seem to run as perfectly as it always had, however that cleared up until Saturday afternoon and it started relatively suddenly running poorly overall, I assumed it was likely an O2 sensor. Installed a new O2 sensor and spark plugs, same result.
Checked the timing, all good there so changed the first filter after the tank and drained and refueled with fresh gas.
Strangely, after idling (roughly and same as before) for a few minutes it worsened with a few pretty cool backfires, decided it was time for a beer and a later second look.
Figured I would throw the easy (within my abilities) at it that I could think of and then consult true professionals to chase distributor, injector, valve train etc issues.
Thanks Matt, appreciate any advice you may have!
Things to check before replacing parts:
1. Fuel pressure
2. Manifold vacuum (2F vaccuum leak achillies heels don't get fixed by EFI)
1. Fuel pressure
Thanks!
Fuel pressure good, I will figure out how to check the manifold vacuum.
Rechecking a couple of things this morning in the garage I can tell it is running very rich from all the gas smoke. The fuel pressure leads me to believe the Pump and Regulator are working and those are not the issue, creates a dead end for my abilities if it is not the IAC, which doesn’t seem to align with the issues those typically create.
Starting to think bad ECU?
