- Joined
- Jul 22, 2012
- Threads
- 640
- Messages
- 17,772
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Thanks!
Fuel pressure good, I will figure out how to check the manifold vacuum.
Rechecking a couple of things this morning in the garage I can tell it is running very rich from all the gas smoke. The fuel pressure leads me to believe the Pump and Regulator are working and those are not the issue, creates a dead end for my abilities if it is not the IAC, which doesn’t seem to align with the issues those typically create.
Starting to think bad ECU?
You have a O2 sensor and a display that tells you what it's reading, there's no need to guess wether it's rich/lean. Which you are just guessing, raw gas can be unburnt fuel from a lean combustion mixture.
You also have a MAP sensor to that can tell you your intake vacuum, that's exactly what it's there for. Only reason to use a mechanical vaccum gauge would be to confirm if the Sniper's iternal map sensor is reading correctly.
