Build HJ61 Cruiser build
I'm studding the tires... will get them center siped too.
That usually does the trick, but i have not tried this with the stt's before.
I'm putting in about 100 in each tire.
uploadfromtaptalk1413570095612-jpg.954652
Self Screw Studs?? Very cool; as I guess winter is approaching you now. I've been on a trip myself, just got back.
No snow in BC yet.
No snow in BC yet.
Yeah, pretty happy with these, been using them since 06 with no issues.
But it's really a manual job to screw them in, at the right depth.
Have not lost any of them.
I had a dedicated winter tire set a while back, and I just made sure they were at the right depth before season start.
Now I'm broke, and can't afford a separate set of winter shoes, but if the stt's perform well as a winter tire, I'll just leave the studs in.
Had a nice trip?
Had a nice trip?
great looking and needed
Had a nice trip?
Yes, great trip. One day bring this rig over for a drive - https://forum.ih8mud.com/threads/so-i-went-for-a-drive-to-chilcotin.821921/#post-9420271
SNOW. So i got to adjust and aim the lights a bit, still needs some tuning.
The light in this video is not very much acurate, but it shows some of the difference in the amber lights in the stock lights, upgraded hi lo bucket for the outer light. amber in all oem lights, and 4300k in the 24v Luminators. They have a great pattern, i think.
overall, i think the video is darker than irl.
Here is a vid of part of my drive home today.
Earlier today, the view was great, but there's not much sun left.
What else have i been up too... Yeah, put in a circulating heater, 1100w.
Thermostat lets it run to 60deg C. after about 45 minutes in freezing temps it starts to kick in and out every other minute or so. Seems legit.
Used the same heater in my 73 diesel before, never had an issue.
it gets water in from the outlet in the block above the oil filter, and lets it trough the cab before entering the engine again.
Engine heats up nice, and the heater does not limit any circulation.
window is even cleared of ice, due to the heat in the heat exhanger cab.
But i dont know if the engine is running warm enough, my mind at least thinks it's taking a bit long to build up to 'working temp. And when running at idle for a few minutes, it cools way down.
My 2H engine never did that. It went fast to operating temps, and stayed there at idle.
I put in i oem 88 deg cold spec t-stat, and swapped the waterpump, as it was a bit of moist in the weep hole.
i wonder if the tap i did from the lower block would interfere with the t-stat, i mean maybe the water flow should not go that way to the cab heater.
If i just put the heater before the hot valve, pulling water from the top of the engine, system still stays stock, but i dont get the benefit of tapping into the lower part of the engine water level, and with the heater in the top, it might not circulate that much. am i making any sense?
I'll experiment with it when it gets colder.
I got an offer i could not refuse, so i now have a 24v comeup dv9i sitting on my shelf, in a crib with 2" connection.
Not sure if im gonna use the crib, i'll have to check how it fits the ironman bumper. maybe i'll just get it going through the winter with a winch plate on the frame extention.
Awsome winch, now im looking for a wireless remote, metaltech has the correct one, but it's a steep price...
http://www.metaltech4x4.com/p-757-comeup-winch-wireless-remote-control.aspx
Winter has raised its ugly head in Canada. I get to find out in a couple of days, as I sit under a palm tree here in Florida. HeHe!
My 12H-T runs cold, kind of scary cold. I drove home last winter through the rockies at -22 C outside, and had to wear my full winter
clothing. Heater could not keep up. So I did a flush and replaced the heater core. It's better, but I now use a canvas cover over the entire
grill on the outside when its' below zero C. It helps. I installed a webasto TSL-17 and never got back into really cold weather to try it out.
I hear some guys leave the webasto running as they drive, haven't tried that yet.
Some of the local experts tell me the 12H-T won't ever get really hot like a gasser for sure, but not even as hot as a 2H. Is this what you
are getting?
Did service the rear brakes... and adjusted the e-brake.
and i found a set of shoes that were narrow, im glad they did not wear a narrow path on the drum!
Well...now there's just no way to upload pictures. i get an error saying its too big file.
Could my account be "full"? no way...
I was gonna show of lots of small findings and fixes, but then i'll just list them!
Rear drum brakes and e-brake adjustment.
Rear locker signal light cable fixed. (lovely to have two red eyes staring at you from the dash)
Rear wheel bearings and hub service.
Diff oil change.
Check tranny and transfer oil change, needs a workout.
Replaced vac solenoid on transfer, and found my front output bearing probably shot.
Serviced the vac lines and the vsv's for the 4wd.
Pulled apart the front knuckle and diff to verify the state of everything.
Front knuckle and cv's need a job.
TRE's need a job.
U joints need a job.
Rubber brake lines need replacement.
Missing a few rubber thingies to block off a few holes in the body. footwell, b-pillar (for electric windows)
And i really need a new bushing for the wiper arm/motor connection.
And it seems my radiator is sweating at the top, cant find out where... its holding pressure well.
So i'm ready for a front 1/2 truck service.
I just need a few parts.
are getting?
Seems to have been a webasto setup in my rig... a bracket and some hoses confirm that.
Do have any more pix or intel on that setup?
My 2H was a lifesaving hot-beast all trough the winter. I flushed the heater core on it, and it was all good.
but this 12ht does only seem to run hot right before the t-stat opens up. At that point, it's similar to the 2H.
I know some of the cruisers had the radiator curtain option on the cold spec. I have used cardboard earlier...
-where did you plumb in the webasto?
Did you have a pic of how you light spread into a wall ? ( light cut )
I'll take a photo of it, how far from the wall do you want the cruiser to be?
Cant upload anything right now, but soon.
that's service !!! :D
10 - 20 ft .?
Here is my install. I wanted it below the highest point, and close to the heater inlets. It's on a 2" channel bracket attached to the firewall, exhaust along the inner fender behind the front wheel. coolant inlet from the line along the top of the engine, hot coolant exits into the
heater switch at the top of the firewall. I added the little coolant filler cap just to ease the removing of air.
The heated coolant enters the cabin heater at the heater switch first, then it exits below into the short piece of red hose (repair job)
which joins the return line from the underseat rear heater. One inlet, then two outlets that join into one. I cleaned up all the wiring behind,
and have the webasto on slots in the firewall bracket so I can loosen the 2 nuts, disconnect the heater hoses, unplug and remove the whole heater in 15 min as complete unit. That way I only have to install 2 small hoses on the engine. So to service the unit if it fails, I can be up and running while that happens.
Maybe... Not modern, but close.
I like that I don't bother other drivers, but I want a oil spray gun on the side of my rig, so I can squirt on the other 'modern' lights.
The retrofitted HID's and poorly aimed new lenses really bother my night vision.
The asymmetric low cut is an LHD EU standard, I think. It throws a bit more light up and to the right, for ditch view.
I think the LHD side is a hella unit, and the rhd side is a cibie unit.
I found a good Thule box for cheap.
Opens both sides, 230cm long, 80 wide.
Quick fists into the rack, so no tool needed to get it off. I'll try not to lose the one key I have...
Practical during winter, both for work and play.
